line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Use a self-contained recursive mutex for API_Mutex_Control. The API
mutexes are protected against asynchronous thread cancellation.
Add dedicated mutexes for libatomic and TOD.
Close #2629.
Close #2630.
The previous rtems_panic() implementation was quite heavy weight. It
depended on _exit() which calls the global destructors. It used
fprintf(stderr, ...) for output which depends on an initialized console
device and the complex fprintf().
Introduce a new fatal source RTEMS_FATAL_SOURCE_PANIC for rtems_panic()
and output via vprintk().
Update #3244.
Delete superfluous INTERNAL_ERROR_POSIX_INIT_THREAD_ENTRY_IS_NULL.
Update #3243.
Update #3243.
Thread priority changes may append or prepend the thread to its priority
group on the scheduler ready queue. Previously, a separate priority
value and a prepend-it flag in the scheduler node were used to propagate
a priority change to the scheduler.
Now, use an append-it bit in the priority control and reduce the plain
priority value to 63 bits.
This change leads to a significant code size reduction (about 25%) of
the SMP schedulers. The negligible increase of the standard priority
scheduler is due to some additional shift operations
(SCHEDULER_PRIORITY_MAP() and SCHEDULER_PRIORITY_UNMAP()).
Before:
text filename
136 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleblock.o
464 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
24 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimple.o
108 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleschedule.o
292 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleunblock.o
264 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimpleyield.o
text filename
280 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityblock.o
488 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerprioritychangepriority.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
164 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityschedule.o
328 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
200 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityyield.o
text filename
24112 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
37204 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
42236 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
After:
text filename
272 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulersimplechangepriority.o
text filename
208 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriority.o
332 sparc-rtems5/c/erc32/cpukit/score/src/libscore_a-schedulerpriorityunblock.o
text filename
18860 arm-rtems5/c/imx7/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
28520 sparc-rtems5/c/gr740/cpukit/score/src/libscore_a-scheduleredfsmp.o
text filename
32664 powerpc-rtems5/c/qoriq_e6500_32/cpukit/score/src/libscore_a-scheduleredfsmp.o
Add a default implementation of _arc4random_getentropy_fail with an
internal error.
Update #3239.
Use only one parameter to compute the next generation. Use index 0 for
LIFO ordering, and index 1 for FIFO ordering.
Move basic timecounter API shared with BSD network stack to
<machine/_timecounter.h>.
Update #3185.
Remove POSIX_API_Control::created_with_explicit_scheduler. Add
Thread_Control::was_created_with_inherited_scheduler. This fixes also
pthread_getattr_np() for Classic tasks.
Update #2514.
Change the chain order relation to use a directly specified left hand
side value. This is similar to _RBTree_Insert_inline() and helps the
compiler to better optimize the code.
Update #3059.
The previous vprintk() implementation had a questionable licence header,
lacks support for the 'z' and 'j' format specifiers, is not robust
against invalid format specifiers, uses a global variable for output.
Replace it with a stripped down version of the FreeBSD kernel kvprintf()
function.
The new implementation allows a low overhead rtems_snprintf() if
necessary.
Update #3199.
Close #3216.
Close #3205.
There is no need to pass in the order relation since the scheduled
threads reside on an already ordered chain. The caller will decide what
to do with the lowest scheduled thread.
Update #3117.
Update #3182.
Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into
_Thread_queue_Context_set_enqueue_do_nothing_extra(). More
_Thread_queue_Context_set_enqueue_*() functions will follow.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Move it from the configuration to a separate variable.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Update #3117.
Update #3182.
Rename _Watchdog_Ticks_from_*() to _Watchdog_Realtime_from_*().
This highlights that these routines are used for the CLOCK_REALTIME
watchdogs (in contrast to CLOCK_MONOTONIC).
Update #3117.
Update #3182.
This value is frequently used. Avoid the function call overhead and the
integer division at run-time.
Update #3117.
Update #3182.
Replace _Thread_Timer_insert_monotonic() with
_Thread_Add_timeout_ticks().
Update #3117.
Update #3182.
Rename _Watchdog_Per_CPU_insert_monotonic() in
_Watchdog_Per_CPU_insert_ticks().
Update #3117.
Update #3182.
Rename PER_CPU_WATCHDOG_RELATIVE in PER_CPU_WATCHDOG_MONOTONIC to
highlight the corresponding POSIX CLOCK_MONOTONIC.
Rename PER_CPU_WATCHDOG_ABSOLUTE in PER_CPU_WATCHDOG_REALTIME to
highlight the corresponding POSIX CLOCK_REALTIME.
Update #3117.
Update #3182.
Hide the boottime and bootimebin globals, provide the getboottime(9) and getboottimebin(9) KPI. Change consumers of boottime to use the KPI. The variables were renamed to avoid shadowing issues with local variables of the same name.
Issue is that boottime* should be adjusted from tc_windup(), which
requires them to be members of the timehands structure. As a
preparation, this commit only introduces the interface.
Some uses of boottime were found doubtful, e.g. NLM uses boottime to
identify the system boot instance. Arguably the identity should not
change on the leap second adjustment, but the commit is about the
timekeeping code and the consumers were kept bug-to-bug compatible.
Tested by: pho (as part of the bigger patch)
Reviewed by: jhb (same)
Discussed with: bde
Sponsored by: The FreeBSD Foundation
MFC after: 1 month
X-Differential revision: https://reviews.freebsd.org/D7302
Update #3175.
Use Processor_mask instead.
Update #2514.
The timestamp are based on the uptime. There is no need for a 64-bit
seconds part. The signed 32-bit seconds part of the sbintime_t limits
the uptime to roughly 68 years.
Close #2740.
Use the timestamps only for uptime based values. Use struct timespec
for the absolute time values (TOD).
Update #2740.
Update #2740.
POSIX mutexes are now available in all configurations and no longer
depend on --enable-posix.
Update #2514.
Update #3112.
POSIX condition variables are now available in all configurations and no
longer depend on --enable-posix.
Update #2514.
Update #3113.
POSIX rwlocks are now available in all configurations and no longer
Update #2514.
Update #3115.
POSIX barriers are now available in all configurations and no longer
Update #2514.
Update #3114.
For semaphore object pointer and object validation see
POSIX_SEMAPHORE_VALIDATE_OBJECT().
Destruction or close of a busy semaphore returns an error status. The
object is not flushed.
POSIX semaphores are now available in all configurations and no longer
Update #2514.
Update #3116.
Reduce size of pthread_once_t and make it zero-initialized.
Update #3142.
The internal status codes encode a Classic rtems_status_code and error
codes used by the POSIX and C11/C++11 APIs. In case the POSIX API is
disabled, the C11/C++11 support must still work.
Close #3167.
Make the RBTree_Node layout independent of RTEMS_DEBUG (and all other
build configuration options). This allows the use of this structure in
Newlib.
Update #3112.
Rename struct Scheduler_Control to _Scheduler_Control to allow its use
in standard header files, e.g. <pthread.h>.
Update #3112.
Update #3059.
Close #2133.
