This function is to big to inline. It leads also to test case
explosion.
http://www.google-melange.com/gci/task/view/google/gci2012/8006220
http://www.google-melange.com/gci/task/view/google/gci2012/8011204
Move post switch hook from API_extensions_Control to new
API_extensions_Post_switch_control. Rename
_API_extensions_Run_postswitch() in _API_extensions_Run_post_switch().
Add _API_extensions_Post_switch_list and
_API_extensions_Add_post_switch().
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
The _API_extensions_Run_postswitch() function is only used in
_Thread_Dispatch(). Avoid superfluous load of _Thread_Executing.
The _User_extensions_Thread_switch() function is only used in
_Thread_Dispatch().
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
Call the fatal handlers of the user extensions before the update of
_Internal_errors_What_happened. This reduces the requirements on the
execution context further. Now a valid read-write data is only required
after the call to the fatal handlers.
This reverts commit 7d0bdcac1ac20d6f22b24689c16e6aa7bc3c1e40.
Add ppc_exc_print_frame_and_context() which prints an exception frame
and the context via printk().
The global exception handler will call now rtems_fatal() with source
RTEMS_FATAL_SOURCE_POWERPC_EXCEPTION. The fatal code will contain the
pointer value to the exception frame.
Delete _TOD_Get_as_timestamp().
Add rtems_bdbuf_fatal_code as a replacement for the previous fatal error
codes. Remove unused error codes. Add new error codes. Use
rtems_fatal() with RTEMS_FATAL_SOURCE_BDBUF as source.
This enum value ensures that the enum type needs at least 32-bits for
architectures with short enums.
Use INTERNAL_ERROR_CPU_ISR_INSTALL_VECTOR on PowerPC for
_CPU_ISR_install_vector().
Add Internal_errors_Information::nest_level. This helps to detect
recursive calls to _Internal_error_Occurred().
Offset calculation was wrong for 16-bit and 64-bit pointer targets.
Remove unused offsets. Move Per_CPU_Control::dispatch_necessary after
Per_CPU_Control::isr_nest_level. Move SMP members to end of structure.
All assembler relevant members are now at the structure beginning.
Define _System_state_Current and _Internal_errors_What_happened in
interr.c to make _Internal_error_Occurred() more independent.
The initial extensions remain now in a read-only table and will not be
copied to work space memory. The extension chains are statically
initialized. This makes it possible to call _User_extensions_Iterate()
independent of the system state. It is now guaranteed that the fatal
callout of the initial extensions will be called provided the stack
pointer, the read-only data, and code memory are valid.
Replace the separate user extension iterations with a single iteration
function. This reduces code size and improves maintainability since the
iteration logic is only in one function. The runtime overhead is
insignificant.
