hardcoded 4 to be compatible with CPUs with 64-bit ints
rather than hardcoded 4 to be compatible with CPUs with 64-bit ints
of GNU C extension
the_class
switch. This was needed to support process wide signals.
can not be part of the locally blocked set since it by itself does not
indicate that the thread is blocked.
in the core to support multiple algorithms to handle cpu time budgetting
which resulted in a change to the calling sequence of _Thread_Initialize.
Makde _Context_Switch_necessary volatile.
_Thread_Ticks_remaining_in_timeslice.
by the api.
Handler could timestamp the starting and stopping of timers. Since
TOD is built on top of Watchdog, this avoided a circular dependency.
which are tasks.
wkspace.h: made initialization routine a regular subroutine
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
in each thread which must be set when the post switch extension is to be run.
are automatically activated upon insertion.
WATCHDOG_BEING_INSERTED.
like signal dispatching.
correct Information block.
