* | Moved _Thread_Information -> _RTEMS_tasks_Information. | Joel Sherrill | 1995-08-23 | 2 | -18/+26 |
| | | | | | | | Added a table of object information control blocks. Modified _Thread_Get so it looks up a thread regardless of which thread management "entity" (manager, internal, etc) actually "owns" it. | ||||
* | Support for variable length names added to Object Handler. This supports | Joel Sherrill | 1995-08-23 | 3 | -52/+101 |
| | | | | | | both fixed length "raw" names and strings from the API's point of view. Both inline and macro implementations were tested. | ||||
* | fix broken RCS Ids -- $ accidentally lost merging changes earlier | Joel Sherrill | 1995-08-22 | 2 | -2/+2 |
* | + Added object type field to object id. | Joel Sherrill | 1995-08-18 | 2 | -12/+61 |
| | | | | | | | | + Added name pointer to Object_Control. + Modified Object Open and Close to address name field. + Removed name as separate element from Thread and Proxy Control. | ||||
* | Numerous miscellaneous features incorporated from Tony Bennett | Joel Sherrill | 1995-08-17 | 3 | -2/+34 |
| | | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables | ||||
* | bug fixes to make macro implementations work | Joel Sherrill | 1995-08-16 | 2 | -4/+4 |
* | added constant for number of notepads | Joel Sherrill | 1995-08-11 | 1 | -8/+10 |
* | Switched to events for mp receive server and eliminated the special | Joel Sherrill | 1995-07-31 | 2 | -21/+1 |
| | | | | blocking mechanism for it. | ||||
* | changed release number to 3.2.0 | Joel Sherrill | 1995-06-04 | 1 | -2/+2 |
* | Fully tested on all in-house targets | Joel Sherrill | 1995-05-24 | 1 | -57/+4 |
* | Initial revision | Joel Sherrill | 1995-05-11 | 25 | -0/+5544 |
