path: root/cpukit/score/include/rtems/system.h (follow)
* Moved include of rtems/score/cpu.h to make sure TRUE and FALSE were defined.Joel Sherrill1997-12-061-2/+2
| | | | | This simple error resulted in the wrong FP context structure being used for hardware contexts on the m68k. This was a difficult problem to find.
* Removed definitions which are now in targopts.h. This eliminates theJoel Sherrill1997-01-291-8/+4
| | | | | need for the "sed'ing" of this file. This should be a significant win when addressing non-unix host and non-gnu toolsets.
* switched from "STATIC INLINE" to "RTEMS_INLINE_ROUTINE"Joel Sherrill1996-07-031-5/+3
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-8/+33
| | | | score, rtems api, or posix api related.
* updates from Tony Bennett for PA and UNIX portsJoel Sherrill1996-01-151-7/+8
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-9/+1
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-0/+6
* Numerous miscellaneous features incorporated from Tony BennettJoel Sherrill1995-08-171-2/+5
| | | | | | | | | (tbennett@divnc.com) including the following major additions: + variable length messages + named devices + debug monitor + association tables/variables
* Initial revisionJoel Sherrill1995-05-111-0/+132
