Update #2825.
The fatal is internal indicator is redundant since the fatal source and
error code uniquely identify a fatal error. Keep the fatal user
extension is internal parameter for backward compatibility and set it to
false always.
Update #2825.
The thread deletion is now supported on SMP.
This change fixes the following PRs:
PR1814: SMP race condition between stack free and dispatch
PR2035: psxcancel reveals NULL pointer access in _Thread_queue_Extract()
The POSIX cleanup handler are now called in the right context (should be
called in the context of the terminating thread).
http://pubs.opengroup.org/onlinepubs/009695399/functions/xsh_chap02_09.html
Add a user extension the reflects a thread termination event. This is
used to reclaim the Newlib reentrancy structure (may use file
operations), the POSIX cleanup handlers and the POSIX key destructors.
Run the thread restart extensions in the context of the restarted
thread. Run them with thread dispatching enabled.
Rename _Internal_error_Occurred() into _Terminate().
This is the result of a sed script which converts all uses
of @{ into a consistent form.
This file contains the parts of <rtems/score/userext.h> that are only
necessary for the RTEMS implementation.
The initial extensions remain now in a read-only table and will not be
copied to work space memory. The extension chains are statically
initialized. This makes it possible to call _User_extensions_Iterate()
independent of the system state. It is now guaranteed that the fatal
callout of the initial extensions will be called provided the stack
pointer, the read-only data, and code memory are valid.
Replace the separate user extension iterations with a single iteration
function. This reduces code size and improves maintainability since the
iteration logic is only in one function. The runtime overhead is
insignificant.
* score/include/rtems/score/userext.h: Documentation.
_User_extensions_Add_API_set
* libmisc/capture/capture.c, posix/src/pthread.c, rtems/src/tasks.c,
score/include/rtems/score/userext.h: Eliminate use of deprecated
rtems_extension. Re-add prototype for _User_extensions_Add_API_set.
* sapi/include/rtems/extension.h, sapi/src/extensiondelete.c,
sapi/src/extensionident.c, sapi/src/extensioncreate.c,
sapi/inline/rtems/extension.inl, score/include/rtems/score/userext.h,
score/src/userextthreaddelete.c, score/src/userext.c,
score/src/userextthreadcreate.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextaddset.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c,
score/src/userextthreadrestart.c: Documentation. The types
User_extensions_routine and rtems_extension are now deprecated.
Removed unused types User_extensions_thread_post_switch_extension and
rtems_task_post_switch_extension. Renamed _User_extensions_Add_API_set()
in _User_extensions_Add_set(). Renamed _User_extensions_Add_set() in
_User_extensions_Add_set_with_table().
* score/src/userextaddapiset.c: Removed file.
* score/Makefile.am: Update.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* libcsupport/include/rtems/libcsupport.h, libcsupport/src/newlibc.c,
sapi/Makefile.am, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/include/rtems/score/userext.h, score/src/chain.c,
score/src/userext.c: Switch to newlib reentrancy extension being
installed in the initial set instead of using rtems_extension_create.
While implementing this, noticed that user extensions and chain code
had multiple functions in a single file which is not desirable in the
SuperCore and API portions of RTEMS, so split these into multiple
files with one function per file. Also noticed that some of user
extension code was inlined for no particular reason so moved that to
C bodies. Split executive shutdown from initialization since not
every application shuts down. Moved __fini call to executive shutdown
to be more symmetrical with where it is called at startup.
* sapi/src/exshutdown.c, score/src/chainappend.c,
score/src/chainextract.c, score/src/chainget.c,
score/src/chaininsert.c, score/src/userextaddapiset.c,
score/src/userextaddset.c, score/src/userextremoveset.c,
score/src/userextthreadbegin.c, score/src/userextthreadcreate.c,
score/src/userextthreaddelete.c, score/src/userextthreadrestart.c,
score/src/userextthreadstart.c, score/src/userextthreadswitch.c: New
files.
* score/inline/rtems/score/userext.inl: Removed.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/context.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/coremsg.inl,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/threadmp.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* score/include/rtems/debug.h, score/include/rtems/score/bitfield.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/userext.inl: Convert to using c99 fixed
size types.
* Per PR142, make task switch extension its own list.
* include/rtems/score/userext.h: Reflect above by adding
User_extensions_Switch_control and adding it to User_extenions_Control.
* inline/rtems/score/userext.inl: Allocate all memory in one chunk
to minimize overhead. Address processing dedicated switch chain.
in each thread which must be set when the post switch extension is to be run.
like signal dispatching.
correct Information block.
