path: root/cpukit/score/include/rtems/score/tqdata.h (follow)
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-8/+9
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-4/+4
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* fix broken RCS Ids -- $ accidentally lost merging changes earlierJoel Sherrill1995-08-221-1/+1
* bug fixes to make macro implementations workJoel Sherrill1995-08-161-2/+2
* Initial revisionJoel Sherrill1995-05-111-0/+90
