Add Timestamp support in the score to return a timestamp in nanoseconds.
Add a test.
Update the RTEMS API documentation.
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
The 64-bit timestamps were introduced to simplify the timestamp
calculations. This works well since nearly all operations are
additions. The previous _TOD_Tickle_ticks() implementation had a
serious performance regression in case of 64-bit timestamps due to the
usage of two 64-bit divisions which are quite expensive on some
architectures.
A new field seconds_trigger in TOD_Control is introduced to trigger the
_Watchdog_Tickle_seconds() in _TOD_Tickle_ticks(). This avoids the
64-bit divisions completely and only 32-bit additions are used.
PR 1914/cpukit
* score/src/timespecgreaterthan.c, score/src/ts64greaterthan.c:
Removed files.
* score/Makefile.am: Reflect changes above.
* score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64divide.c, score/src/ts64dividebyinteger.c,
score/src/ts64equalto.c, score/src/ts64getnanoseconds.c,
score/src/ts64getseconds.c, score/src/ts64lessthan.c,
score/src/ts64set.c, score/src/ts64settozero.c,
score/src/ts64subtract.c, score/src/ts64toticks.c,
score/src/ts64totimespec.c: Use CPU_TIMESTAMP_USE_STRUCT_TIMESPEC,
CPU_TIMESTAMP_USE_INT64, and CPU_TIMESTAMP_USE_INT64_INLINE. Removed
copy and paste.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* libnetworking/rtems/mkrootfs.h,
score/include/rtems/score/timestamp.h: Move 'extern "C"'.
* score/include/rtems/score/timestamp.h,
score/include/rtems/score/watchdog.h:
Misc. doxygen fixes.
* score/Makefile.am, score/preinstall.am,
score/include/rtems/score/timestamp.h: Add 64-bit implementation of
SuperCore Timestamps. Tested on PowerPC/psim and SPARC/sis.
* score/include/rtems/score/timestamp64.h, score/src/ts64addto.c,
score/src/ts64getseconds.c, score/src/ts64greaterthan.c,
score/src/ts64lessthan.c, score/src/ts64set.c,
score/src/ts64settozero.c, score/src/ts64subtract.c,
score/src/ts64toticks.c, score/src/ts64totimespec.c: New files.
* libcsupport/src/__times.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, posix/src/clockgettime.c,
posix/src/pthread.c, posix/src/timersettime.c,
rtems/src/clockgetsecondssinceepoch.c, rtems/src/clockgetuptime.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c, rtems/src/taskwakewhen.c,
rtems/src/timerfirewhen.c, rtems/src/timerserver.c,
rtems/src/timerserverfirewhen.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/thread.h,
score/include/rtems/score/tod.h, score/src/coretod.c,
score/src/coretodget.c, score/src/coretodgetuptime.c,
score/src/coretodset.c, score/src/coretodtickle.c,
score/src/threaddispatch.c, score/src/threadinitialize.c: Add
SuperCore handler Timestamp to provide an opaque class for the
representation and manipulation of uptime, time of day, and the
difference between two timestamps. By using SuperCore Timestamp, it
is clear which methods and APIs really have to be struct timespec and
which can be in an optimized native format.
score/src/coretodgetuptimetimespec.c: New files.
