path: root/cpukit/score/include/rtems/score/threadqimpl.h (follow)
* score: Move thread queue timeout handlingSebastian Huber2017-10-241-25/+85
| | | | | Update #3117. Update #3182.
* score: Rename function threadq support functionSebastian Huber2017-10-241-5/+5
| | | | | | | | | Rename _Thread_queue_Context_set_do_nothing_enqueue_callout() into _Thread_queue_Context_set_enqueue_do_nothing_extra(). More _Thread_queue_Context_set_enqueue_*() functions will follow. Update #3117. Update #3182.
* score: Add _Thread_queue_Dispatch_disable()Sebastian Huber2017-10-101-0/+10
* score: Add RTEMS_HAVE_MEMBER_SAME_TYPE()Sebastian Huber2017-07-311-2/+6
| | | | This fixes some "variably modified" warnings and a clang compile error.
* score: Add _Thread_queue_Object_nameSebastian Huber2017-01-311-2/+46
| | | | | | | | | | | | | Add the special thread queue name _Thread_queue_Object_name to mark thread queues embedded in an object with identifier. Using the special thread state STATES_THREAD_QUEUE_WITH_IDENTIFIER is not reliable for this purpose since the thread wait information and thread state are protected by different SMP locks in separate critical sections. Remove STATES_THREAD_QUEUE_WITH_IDENTIFIER. Add and use _Thread_queue_Object_initialize(). Update #2858.
* score: Add Thread_queue_Queue::nameSebastian Huber2017-01-131-12/+26
| | | | Update #2858.
* score: Improve SMP lock debug supportSebastian Huber2017-01-111-1/+1
| | | | | The CPU index starts with zero. Increment it by one, to allow global SMP locks to reside in the BSS section.
* score: Fix debug thread queue context initSebastian Huber2016-12-021-0/+2
| | | | | On ARM Thumb we may have function addresses ending with 0x7f, if we are lucky.
* score: Fix thread queue context initializationSebastian Huber2016-11-281-3/+4
| | | | | Initialize the thread queue context with invalid data in debug configurations to catch missing set up steps.
* score: Optimize _Thread_queue_Enqueue()Sebastian Huber2016-11-241-8/+44
| | | | | | | | | Move thread state for _Thread_queue_Enqueue() to the thread queue context. This reduces the parameter count of _Thread_queue_Enqueue() from five to four (ARM for example has only four function parameter registers). Since the thread state is used after several function calls inside _Thread_queue_Enqueue() this parameter was saved on the stack previously.
* score: Rename _Thread_queue_Enqueue_critical()Sebastian Huber2016-11-231-48/+10
| | | | | Delete unused _Thread_queue_Enqueue() and rename _Thread_queue_Enqueue_critical() to _Thread_queue_Enqueue().
* score: Add thread queue enqueue calloutSebastian Huber2016-11-231-10/+35
| | | | | | | Replace the expected thread dispatch disable level with a thread queue enqueue callout. This enables the use of _Thread_Dispatch_direct() in the thread queue enqueue procedure. This avoids impossible exection paths, e.g. Per_CPU_Control::dispatch_necessary is always true.
* score: Optimize self-contained objectsSebastian Huber2016-11-181-0/+19
| | | | Avoid use of the stack for the hot paths.
* score: Use non-inline thread queue lock opsSebastian Huber2016-11-041-19/+35
| | | | | | This reduces the code size and helps to reduce the amount of testing. Hot paths can use the _Thread_queue_Queue_acquire_critical() and _Thread_queue_Queue_release_critical() functions which are still inline.
* score: First part of new MrsP implementationSebastian Huber2016-11-021-0/+62
| | | | Update #2556.
* score: Scheduler node awareness for thread queuesSebastian Huber2016-09-211-3/+3
| | | | | | | | Maintain the priority of a thread for each scheduler instance via the thread queue enqueue, extract, priority actions and surrender operations. This replaces the primitive priority boosting. Update #2556.
* score: Rework thread priority managementSebastian Huber2016-09-211-80/+65
| | | | | | | | | | | | | | | | | | | | | | | | | Add priority nodes which contribute to the overall thread priority. The actual priority of a thread is now an aggregation of priority nodes. The thread priority aggregation for the home scheduler instance of a thread consists of at least one priority node, which is normally the real priority of the thread. The locking protocols (e.g. priority ceiling and priority inheritance), rate-monotonic period objects and the POSIX sporadic server add, change and remove priority nodes. A thread changes its priority now immediately, e.g. priority changes are not deferred until the thread releases its last resource. Replace the _Thread_Change_priority() function with * _Thread_Priority_perform_actions(), * _Thread_Priority_add(), * _Thread_Priority_remove(), * _Thread_Priority_change(), and * _Thread_Priority_update(). Update #2412. Update #2556.
* score: Introduce Thread_queue_Lock_contextSebastian Huber2016-09-081-6/+6
| | | | | | Introduce Thread_queue_Lock_context to contain the context necessary for thread queue lock and thread wait lock acquire/release operations to reduce the Thread_Control size.
* score: Simplify thread queue acquire/releaseSebastian Huber2016-09-081-10/+32
* score: Introduce thread queue surrender operationSebastian Huber2016-08-111-25/+0
| | | | | | This is an optimization for _Thread_queue_Surrender(). It helps to encapsulate the priority boosting in the priority inheritance thread queue operations.
* score: Add _Thread_queue_Surrender()Sebastian Huber2016-08-111-0/+27
| | | | | Add _Thread_queue_Surrender() to unify the mutex surrender procedures which involve a thread queue operation.
* score: Fix and simplify thread wait locksSebastian Huber2016-08-031-106/+6
| | | | | | | | | | There was a subtile race condition in _Thread_queue_Do_extract_locked(). It must first update the thread wait flags and then restore the default thread wait state. In the previous implementation this could lead under rare timing conditions to an ineffective _Thread_Wait_tranquilize() resulting to a corrupt system state. Update #2556.
* score: Add deadlock detectionSebastian Huber2016-07-271-0/+38
| | | | | | | | | | The mutex objects use the owner field of the thread queues for the mutex owner. Use this and add a deadlock detection to _Thread_queue_Enqueue_critical() for thread queues with an owner. Update #2412. Update #2556. Close #2765.
* score: Turn thread lock into thread wait lockSebastian Huber2016-07-271-3/+145
| | | | | | | | | The _Thread_Lock_acquire() function had a potentially infinite run-time due to the lack of fairness at atomic operations level. Update #2412. Update #2556. Update #2765.
* score: Priority inherit thread queue operationsSebastian Huber2016-07-271-0/+23
| | | | | | | | | Move the priority change due to priority interitance to the thread queue enqueue operation to simplify the locking on SMP configurations. Update #2412. Update #2556. Update #2765.
* cpukit: refactor nanosleep and use 64-bit timeout for threadqGedare Bloom2016-07-261-1/+1
| | | | | | | | | | * Fixes a bug with elapsed time calculations misusing absolute time arguments in nanosleep_helper by passing the requested relative interval. * Fixes a bug with truncation of absolute timeouts by passing the full 64-bit value to Thread_queue_Enqueue. * Share yield logic between nanosleep and clock_nanosleep. updates #2732
* cpukit: Add and use Watchdog_Discipline.Gedare Bloom2016-07-251-7/+60
| | | | | | | | | Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE, or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline of WATCHDOG_NO_TIMEOUT. updates #2732
* score: Add debug support to chainsSebastian Huber2016-07-221-0/+2
| | | | | | | This helps to detect * double insert, append, prepend errors, and * get from empty chain errors.
* score: _CORE_mutex_Check_dispatch_for_seize()Sebastian Huber2016-05-301-12/+38
| | | | | | | | | | | Move the safety check performed by _CORE_mutex_Check_dispatch_for_seize() out of the performance critical path and generalize it. Blocking on a thread queue with an unexpected thread dispatch disabled level is illegal in all system states. Add the expected thread dispatch disable level (which may be 1 or 2 depending on the operation) to Thread_queue_Context and use it in _Thread_queue_Enqueue_critical().
* score: Add _Thread_queue_Context_set_MP_callout()Sebastian Huber2016-05-301-25/+22
| | | | | | Add _Thread_queue_Context_set_MP_callout() to simplify _Thread_queue_Context_initialize(). This makes it possible to more easily add additional fields to Thread_queue_Context.
* score: Adjust thread queue layoutSebastian Huber2016-05-301-3/+4
| | | | | | Adjust thread queue layout according to Newlib. This makes it possible to use the same implementation for <sys/lock.h> and CORE mutexes in the future.
* score: Add Status_Control for all APIsSebastian Huber2016-05-261-5/+35
| | | | | | | | | | | Unify the status codes of the Classic and POSIX API to use the new enum Status_Control. This eliminates the Thread_Control::Wait::timeout_code field and the timeout parameter of _Thread_queue_Enqueue_critical() and _MPCI_Send_request_packet(). It gets rid of the status code translation tables and instead uses simple bit operations to get the status for a particular API. This enables translation of status code constants at compile time. Add _Thread_Wait_get_status() to avoid direct access of thread internal data structures.
* score: Move thread queue MP callout to contextSebastian Huber2016-05-251-109/+82
| | | | | | | | Drop the multiprocessing (MP) dependent callout parameter from the thread queue extract, dequeue, flush and unblock methods. Merge this parameter with the lock context into new structure Thread_queue_Context. This helps to gets rid of the conditionally compiled method call helpers.
* score: Get rid of mp_id parameterSebastian Huber2016-05-251-30/+8
| | | | | Get rid of the mp_id parameter used for some thread queue methods. Use THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
* score: Move thread queue object supportSebastian Huber2016-05-251-0/+27
* mpci: Fix thread queue flush methodSebastian Huber2016-05-251-49/+11
| | | | | | | We must call the MP callout for proxies if we unblock them after a thread queue extraction. This was missing in _Thread_queue_Flush_critical(). Move thread remove timer and unblock code to new function _Thread_Remove_timer_and_unblock().
* score: Use _RBTree_Insert_inline()Sebastian Huber2016-05-201-15/+0
| | | | | | Use _RBTree_Insert_inline() for priority thread queues. Update #2556.
* score: Avoid Giant lock for scheduler set/getSebastian Huber2016-05-121-3/+23
| | | | Update #2555.
* score: Add _Thread_queue_Is_lock_owner()Sebastian Huber2016-05-121-3/+45
| | | | Add _Thread_queue_Is_lock_owner() in case RTEMS_DEBUG is defined.
* score: Add _Thread_queue_Flush_default_filter()Sebastian Huber2016-04-221-0/+15
* score: Add _Thread_queue_Is_empty()Sebastian Huber2016-04-221-0/+7
* score: Introduce _Thread_queue_Flush_critical()Sebastian Huber2016-04-211-24/+63
| | | | | | | | Replace _Thread_queue_Flush() with _Thread_queue_Flush_critical() and add a filter function for customization of the thread queue flush operation. Update #2555.
* score: Rework MP thread queue callout supportSebastian Huber2016-04-061-31/+182
| | | | | | | | | | | | | | | | | | | | | | | | | | | | The thread queue implementation was heavily reworked to support SMP. This broke the multiprocessing support of the thread queues. This is fixed by this patch. A thread proxy is unblocked due to three reasons 1) timeout, 2) request satisfaction, and 3) extraction. In case 1) no MPCI message must be sent. This is ensured via the _Thread_queue_MP_callout_do_nothing() callout set during _Thread_MP_Allocate_proxy(). In case 2) and 3) an MPCI message must be sent. In case we interrupt the blocking operation during _Thread_queue_Enqueue_critical(), then this message must be sent by the blocking thread. For this the new fields Thread_Proxy_control::thread_queue_callout and Thread_Proxy_control::thread_queue_id are used. Delete the individual API MP callout types and use Thread_queue_MP_callout throughout. This type is only defined in multiprocessing configurations. Prefix the multiprocessing parameters with mp_ to ease code review. Multiprocessing specific parameters are optional due to use of a similar macro pattern. There is no overhead for non-multiprocessing configurations.
* score: _Thread_queue_Flush() parameter changesSebastian Huber2016-04-061-20/+61
| | | | | | | | | | | | Change _Thread_queue_Flush() into a macro that invokes _Thread_queue_Do_flush() with the parameter set defined by RTEMS_MULTIPROCESSING. For multiprocessing configurations add the object identifier to avoid direct use of the thread wait information. Use mp_ prefix for multiprocessing related parameters. Rename Thread_queue_Flush_callout to Thread_queue_MP_callout since this type will be re-used later for other operations as well.
* score: Remove Thread_queue_Queue::operations fieldSebastian Huber2016-03-291-60/+32
| | | | | | | | | Remove the Thread_queue_Queue::operations field to reduce the size of this structure. Add a thread queue operations parameter to the _Thread_queue_First(), _Thread_queue_First_locked(), _Thread_queue_Enqueue(), _Thread_queue_Dequeue() and _Thread_queue_Flush() functions. This is a preparation patch to reduce the size of several synchronization objects.
* score: Implement priority boostingSebastian Huber2015-09-041-0/+25
* score: Implement SMP-specific priority queueSebastian Huber2015-09-041-0/+16
* score: Add thread queue for self-contained objectsSebastian Huber2015-07-301-0/+18
* score: Use a plain ticket lock for thread locksSebastian Huber2015-07-301-9/+64
| | | | | | This enables external libraries to use thread locks since they are independent of the actual RTEMS build configuration, e.g. profiling enabled or disabled.
* score: Move wait flag update to tq extractSebastian Huber2015-07-231-1/+12
| | | | | | This makes it possible to use _Thread_queue_Extract_locked() for barrier operations which extract all threads on the queue in one critical section.
