* _Thread_Priority_add(),
* _Thread_Priority_remove(),
* _Thread_Priority_update().
Update #2412.
Update #2556.
Introduce Thread_queue_Lock_context to contain the context necessary for
thread queue lock and thread wait lock acquire/release operations to
reduce the Thread_Control size.
This is an optimization for _Thread_queue_Surrender(). It helps to
encapsulate the priority boosting in the priority inheritance thread
queue operations.
There was a subtile race condition in _Thread_queue_Do_extract_locked().
It must first update the thread wait flags and then restore the default
thread wait state. In the previous implementation this could lead under
rare timing conditions to an ineffective _Thread_Wait_tranquilize()
resulting to a corrupt system state.
Update #2556.
The mutex objects use the owner field of the thread queues for the mutex
owner. Use this and add a deadlock detection to
_Thread_queue_Enqueue_critical() for thread queues with an owner.
Update #2412.
Update #2556.
Close #2765.
The _Thread_Lock_acquire() function had a potentially infinite run-time
due to the lack of fairness at atomic operations level.
Update #2412.
Update #2556.
Update #2765.
Move the priority change due to priority interitance to the thread queue
enqueue operation to simplify the locking on SMP configurations.
Update #2412.
Update #2556.
Update #2765.
Clock disciplines may be WATCHDOG_RELATIVE, WATCHDOG_ABSOLUTE,
or WATCHDOG_NO_TIMEOUT. A discipline of WATCHDOG_RELATIVE with
a timeout of WATCHDOG_NO_TIMEOUT is equivalent to a discipline
of WATCHDOG_NO_TIMEOUT.
updates #2732
Move the safety check performed by
_CORE_mutex_Check_dispatch_for_seize() out of the performance critical
path and generalize it. Blocking on a thread queue with an unexpected
thread dispatch disabled level is illegal in all system states.
Add the expected thread dispatch disable level (which may be 1 or 2
depending on the operation) to Thread_queue_Context and use it in
_Thread_queue_Enqueue_critical().
Add _Thread_queue_Context_set_MP_callout() to simplify
_Thread_queue_Context_initialize(). This makes it possible to more
easily add additional fields to Thread_queue_Context.
Adjust thread queue layout according to Newlib. This makes it possible
to use the same implementation for <sys/lock.h> and CORE mutexes in the
future.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Add _Thread_queue_Is_lock_owner() in case RTEMS_DEBUG is defined.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
This enables external libraries to use thread locks since they are
independent of the actual RTEMS build configuration, e.g. profiling
enabled or disabled.
Use a leading underscore in the structure name to allow forward
declarations in standard header files provided by Newlib and GCC.
Add a leading underscore to the structure name to allow forward
Move the storage for the thread queue heads to the threads. Each thread
provides a set of thread queue heads allocated from a dedicated memory
pool. In case a thread blocks on a queue, then it lends its heads to
the queue. In case the thread unblocks, then it takes a free set of
threads from the queue. Since a thread can block on at most one queue
this works. This mechanism is used in FreeBSD. The motivation for this
change is to reduce the memory demands of the synchronization objects.
On a 32-bit uni-processor configuration the Thread_queue_Control size is
now 8 bytes, compared to 64 bytes in RTEMS 4.10 (other changes reduced
the size as well).
Separate the thread queue heads and lock from the operations. This
enables the support for light weight objects which only support one
queuing discipline.
Avoid Thread_Control typedef in <rtems/score/percpu.h>. This helps to
get rid of the <rtems/score/percpu.h> include in <rtems/score/thread.h>
which exposes a lot of implementation details.
Use a parameter for _Thread_queue_Enqueue() instead to reduce memory
usage.
Use thread wait flags for synchronization. The enqueue operation is now
part of the initial critical section. This is the key change and
enables fine grained locking on SMP for objects using a thread queue
like semaphores and message queues.
Update #2273.
Move thread queue discipline specific operations into
Thread_queue_Operations. Use a separate node in the thread control
block for the thread queue to make it independent of the scheduler data
structures.
Update #2273.
Replace the Thread_Priority_control with more general
Thread_queue_Operations which will be used for generic priority change,
timeout, signal and wait queue operations in the future.
Update #2273.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
usage.
There was a lot of duplication between the discipline subroutines.
With the transition to RBTrees for priority discipline, there were
only a few lines of source code manipulating the data structure
for FIFO and priority. Thus is made sense to fold these back
into the main methods.
As part of doing this all of the tests for discipline were changed
to be in the same order.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* libnetworking/rtems/mkrootfs.h,
score/include/rtems/score/timestamp.h: Move 'extern "C"'.
