Move implementation specific parts of thread.h and thread.inl into new
header file threadimpl.h. The thread.h contains now only the
application visible API.
Remove superfluous header file includes from various files.
Do not redefine CPU_USE_DEFERRED_FP_SWITCH.
Delete _Thread_libc_reent and add __getreent() instead according to
__DYNAMIC_REENT__ define.
For SMP configurations __DYNAMIC_REENT__ must be defined.
A Newlib including the following patch is required:
2013-07-09 Sebastian Huber <sebastian.huber@embedded-brains.de>
* libc/include/sys/config.h (__DYNAMIC_REENT__): Define for RTEMS.
The new Simple SMP Scheduler allocates a processor for the processor
count highest priority ready threads. The thread priority and position
in the ready chain are the only information to determine the scheduling
decision. Threads with an allocated processor are in the scheduled
chain. After initialization the scheduled chain has exactly processor
count nodes. Each processor has exactly one allocated thread after
initialization. All enqueue and extract operations may exchange threads
with the scheduled chain. One thread will be added and another will be
removed. The scheduled and ready chain is ordered according to the
thread priority order. The chain insert operations are O(count of ready
threads), thus this scheduler is unsuitable for most real-time
applications.
The thread preempt mode will be ignored.
Add and use _Scheduler_Start_idle().
Move thread dispatch declarations and inline functions to new header
<rtems/score/threaddispatch.h> to make it independent of the
Thread_Control structure. This avoids a cyclic dependency in case
thread dispatch functions are used for the object implementation.
Move the SMP lock implementation to the CPU port. An optimal SMP lock
implementation is highly architecture dependent. For example the memory
models may be fundamentally different.
The new SMP lock API has a flaw. It does not provide the ability to use
a local context for acquire and release pairs. Such a context is
necessary to implement for example the Mellor-Crummey and Scott (MCS)
locks. The SMP lock is currently used in _Thread_Disable_dispatch() and
_Thread_Enable_dispatch() and makes them to a giant lock acquire and
release. Since these functions do not pass state information via a
local context there is currently no use case for such a feature.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
At the previous location, uint32_t was not available.
PR 1938/cpukit
* score/include/rtems/score/thread.h: Removed obsolete suspend_count
field from Thread_Control.
* score/include/rtems/score/thread.h: Ensure CBS builds with POSIX
disabled.
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
* score/Makefile.am, score/include/rtems/score/thread.h,
score/inline/rtems/score/thread.inl: Add smp support to dispable
dispatch level accesses.
* score/src/threaddispatchdisablelevel.c: New file.
PR 1788/cpukit
* score/include/rtems/score/percpu.h,
score/include/rtems/score/thread.h: Make time of last context switch
part of per cpu information since each core has a different context
switch to track.
PR 1782/cpukit
* score/include/rtems/score/thread.h: Disable deferred FPU context
switches when SMP is enabled. Per code tracking of deferred contexts
is not implemented.
PR 1777/cpukit
* libcsupport/src/malloc_deferred.c, libcsupport/src/realloc.c,
score/Makefile.am, score/cpu/lm32/irq.c, score/cpu/nios2/irq.c,
score/inline/rtems/score/thread.inl, score/src/heapfree.c,
score/src/pheapwalk.c, score/src/smp.c, score/src/threaddispatch.c:
Consolidated access to _Thread_Dispatch_disable_level.
* score/src/threaddisabledispatch.c, score/src/threadenabledispatch.c:
New files.
* rtems/src/taskresume.c, score/Makefile.am,
score/include/rtems/score/thread.h: Convert _Thread_Resume and
_Thread_Suspend into macros.
* score/src/threadresume.c, score/src/threadsuspend.c: Removed.
* sapi/include/confdefs.h, score/Makefile.am,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/scheduler.c, score/src/schedulerpriority.c,
score/src/schedulerpriorityblock.c,
score/src/schedulerpriorityschedule.c,
score/src/schedulerpriorityunblock.c,
score/src/schedulerpriorityyield.c, score/src/threadchangepriority.c,
score/src/threadclose.c, score/src/threadinitialize.c,
score/src/threadsetpriority.c, score/src/threadsettransient.c:
Significant clean up on Scheduler Plugin Interface. Names were
shortened. Missing operations added. Many scheduler files had
unneeded includes removed. Made pointer to scheduler information in
Thread_Control and Scheduler_Control a void * pointer because the
thread and scheduler wrapper should be unaware of scheduler types AND
this is broken for user provided schedulers.
* score/src/schedulerpriorityallocate.c,
score/src/schedulerpriorityenqueue.c,
score/src/schedulerpriorityenqueuefirst.c,
score/src/schedulerpriorityextract.c,
score/src/schedulerpriorityfree.c,
score/src/schedulerpriorityupdate.c: New files.
* score/src/schedulerprioritythreadschedulerallocate.c,
score/src/schedulerprioritythreadschedulerfree.c,
score/src/schedulerprioritythreadschedulerupdate.c: Removed.
PR 1647/cpukit
* posix/src/nanosleep.c, posix/src/sched_yield.c,
rtems/src/taskwakeafter.c, sapi/include/confdefs.h,
sapi/include/rtems/config.h, sapi/src/exinit.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/thread.inl, score/src/thread.c,
score/src/threadchangepriority.c, score/src/threadclearstate.c,
score/src/threadready.c, score/src/threadresume.c,
score/src/threadsetpriority.c, score/src/threadsetstate.c,
score/src/threadsettransient.c, score/src/threadsuspend.c,
score/src/threadtickletimeslice.c: Refactor scheduler out of thread
handler to facilitate alternate scheduler implementations.
* score/src/threadyieldprocessor.c: Removed.
* score/src/schedulerprioritythreadschedulerupdate.c,
score/src/schedulerpriorityblock.c, score/src/scheduler.c,
score/src/schedulerpriority.c, score/src/schedulerpriorityyield.c,
score/inline/rtems/score/schedulerpriority.inl: New files.
PR 1635/cpukit
* sapi/src/exinit.c, score/Makefile.am, score/preinstall.am,
score/inline/rtems/score/priority.inl,
score/src/threadsettransient.c, score/src/threadsuspend.c:
Refactoring of priority handling, to isolate the bitmap
implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* score/include/rtems/score/prioritybitmap.h,
score/inline/rtems/score/prioritybitmap.inl: New files.
PR 1573/cpukit
* configure.ac, posix/src/killinfo.c,
posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c,
posix/src/pthreadkill.c, posix/src/pthreadsigmask.c,
rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am,
score/preinstall.am, score/include/rtems/system.h,
score/include/rtems/score/context.h, score/include/rtems/score/isr.h,
score/include/rtems/score/thread.h, score/src/isr.c,
score/src/isrthreaddispatch.c, score/src/thread.c,
score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu
data structure which contains the information required by RTEMS for
each CPU core. This encapsulates information such as thread
executing, heir, idle and dispatch needed.
* score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
PR 1589/cpukit
score/inline/rtems/score/thread.inl: Make _Thread_Evaluate_mode() an
inline method. It is only used in one place and relatively simple.
* score/src/threadevaluatemode.c: Removed.
PR 1590/cpukit
score/src/threadtickletimeslice.c: Remove _Thread_Reset_timeslice and
replaces its single use with a call to the functionally equivalent
_Thread_Yield_processor().
* score/src/threadresettimeslice.c: Removed.
* score/include/rtems/score/thread.h: Remove ITRON.
* score/include/rtems/score/object.h,
score/include/rtems/score/thread.h: Remove prototypes for ITRON
only methods removed by Ralf.
* configure.ac, libcsupport/src/__times.c,
libmisc/cpuuse/cpuusagedata.c, libmisc/cpuuse/cpuusagereport.c,
libmisc/cpuuse/cpuusagereset.c, rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/types.h, rtems/src/ratemongetstatistics.c,
rtems/src/ratemongetstatus.c, rtems/src/ratemonperiod.c,
rtems/src/ratemonreportstatistics.c,
score/include/rtems/score/thread.h, score/src/threaddispatch.c,
score/src/threadinitialize.c, score/src/threadtickletimeslice.c:
Changed the configuration of statistics granularity to use just one
define.
* score/include/rtems/score/thread.h: Revert accidentally committed
change. It is possible that _Thread_Dispatch_disable_level can be an
8-bit variable but this impacts assembly and must be carefully
considered.
PR pr1462/cpukit
* rtems/include/rtems/rtems/ratemon.h, rtems/src/ratemongetstatus.c,
rtems/src/ratemonperiod.c, rtems/src/ratemontimeout.c,
score/include/rtems/score/thread.h: Fix bugs in rate monotonic
statistics.
* score/include/rtems/score/thread.h, score/src/threadinitialize.c,
score/src/threadstackfree.c: Disable capability for API to let user
provide thread stack when no API configured includes this capability.
