The new Simple SMP Scheduler allocates a processor for the processor
count highest priority ready threads. The thread priority and position
in the ready chain are the only information to determine the scheduling
decision. Threads with an allocated processor are in the scheduled
chain. After initialization the scheduled chain has exactly processor
count nodes. Each processor has exactly one allocated thread after
initialization. All enqueue and extract operations may exchange threads
with the scheduled chain. One thread will be added and another will be
removed. The scheduled and ready chain is ordered according to the
thread priority order. The chain insert operations are O(count of ready
threads), thus this scheduler is unsuitable for most real-time
applications.
The thread preempt mode will be ignored.
Delete _Scheduler_priority_Tick(). Use _SMP_Get_processor_count() for
default tick operation. Delete _Scheduler_simple_smp_Tick().
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
PR 1895/cpukit
* rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, sapi/include/confdefs.h,
score/Makefile.am, score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/coremutexseize.c: Add priority_compare and release_job
hooks interfaces to scheduler interface.
* score/src/schedulerpriorityprioritycompare.c,
score/src/schedulerpriorityreleasejob.c: New files.
* score/Makefile.am, score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmptick.c: Build schedulersimplesmptick.c
and fix typos.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
PR 1789/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple SMP Priority Scheduler.
* score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmpblock.c,
score/src/schedulersimplesmpschedule.c,
score/src/schedulersimplesmpunblock.c: New files.
