Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
Add Thread_Control::is_in_the_air field if configured for SMP. This
helps to simplify the extract operation and avoids superfluous
inter-processor interrupts. Move the processor allocation step into the
enqueue operation.
Add and use _Scheduler_simple_smp_Get_highest_ready(). Add and use
_Scheduler_SMP_Get_lowest_scheduled().
Rename _Scheduler_simple_smp_Start_idle() to
_Scheduler_SMP_Start_idle().
Replace Scheduler_simple_smp_Control with Scheduler_SMP_Control. Rename
_Scheduler_simple_smp_Instance() to _Scheduler_SMP_Instance().
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
Rename _Scheduler_simple_Update() in _Scheduler_default_Update().
Rename _Scheduler_simple_Allocate() in _Scheduler_default_Allocate().
Rename _Scheduler_simple_Free() in _Scheduler_default_Free().
Rename _Scheduler_priority_Release_job() into
_Scheduler_default_Release_job().
The new Simple SMP Scheduler allocates a processor for the processor
count highest priority ready threads. The thread priority and position
in the ready chain are the only information to determine the scheduling
decision. Threads with an allocated processor are in the scheduled
chain. After initialization the scheduled chain has exactly processor
count nodes. Each processor has exactly one allocated thread after
initialization. All enqueue and extract operations may exchange threads
with the scheduled chain. One thread will be added and another will be
removed. The scheduled and ready chain is ordered according to the
thread priority order. The chain insert operations are O(count of ready
threads), thus this scheduler is unsuitable for most real-time
applications.
The thread preempt mode will be ignored.
Delete _Scheduler_priority_Tick(). Use _SMP_Get_processor_count() for
default tick operation. Delete _Scheduler_simple_smp_Tick().
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
PR 1895/cpukit
* rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemonperiod.c, sapi/include/confdefs.h,
score/Makefile.am, score/include/rtems/score/scheduler.h,
score/include/rtems/score/schedulerpriority.h,
score/include/rtems/score/schedulersimple.h,
score/include/rtems/score/schedulersimplesmp.h,
score/inline/rtems/score/scheduler.inl,
score/inline/rtems/score/schedulerpriority.inl,
score/src/coremutexseize.c: Add priority_compare and release_job
hooks interfaces to scheduler interface.
* score/src/schedulerpriorityprioritycompare.c,
score/src/schedulerpriorityreleasejob.c: New files.
* score/Makefile.am, score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmptick.c: Build schedulersimplesmptick.c
and fix typos.
PR 1819/cpukit
* rtems/src/clocktick.c, score/Makefile.am,
score/inline/rtems/score/scheduler.inl: Add a scheduler entry point
which is invoked at each clock tick. _Thread_Tickle_timeslice() is
now a method owned by the Deterministic Priority Scheduler and shared
by the Simple Priority Scheduler. The Simple SMP Scheduler has its
own variation on this which does timeslicing bookkeeping on all
cores.
* score/src/schedulerprioritytick.c,
score/src/schedulersimplesmptick.c: New files.
* score/src/threadtickletimeslice.c: Removed.
PR 1789/cpukit
* sapi/include/confdefs.h, score/Makefile.am, score/preinstall.am: Add
Simple SMP Priority Scheduler.
* score/include/rtems/score/schedulersimplesmp.h,
score/src/schedulersimplesmpblock.c,
score/src/schedulersimplesmpschedule.c,
score/src/schedulersimplesmpunblock.c: New files.
