By convention, thread priorities must be integers in RTEMS. Smaller
values represent more important threads.
Use priority maximum of scheduler instance. This avoids a potential
memory corruption on SMP configurations.
This emphasizes that the scheduler node of a thread is returned and this
is not a function working with scheduler nodes like the other *_Node_*()
functions.
This reduces the API to the minimum data structures to maximize the
re-usability.
Delete _Scheduler_priority_Get_scheduler_info().
The function to change a thread priority was too complex. Simplify it
with a new scheduler operation. This increases the average case
performance due to the simplified logic. The interrupt disabled
critical section is a bit prolonged since now the extract, update and
enqueue steps are executed atomically. This should however not impact
the worst-case interrupt latency since at least for the Deterministic
Priority Scheduler this sequence can be carried out with a wee bit of
instructions and no loops.
Add _Scheduler_Change_priority() to replace the sequence of
- _Thread_Set_transient(),
- _Scheduler_Extract(),
- _Scheduler_Enqueue(), and
- _Scheduler_Enqueue_first().
Delete STATES_TRANSIENT, _States_Is_transient() and
_Thread_Set_transient() since this state is now superfluous.
With this change it is possible to get rid of the
SCHEDULER_SMP_NODE_IN_THE_AIR state. This considerably simplifies the
implementation of the new SMP locking protocols.
Delete unused function _Scheduler_priority_Ready_queue_requeue().
Rename scheduler per-thread information into scheduler nodes using
Scheduler_Node as the base type. Use inheritance for specialized
schedulers.
Move the scheduler specific states from the thread control block into
the scheduler node structure.
Validate the SMP scheduler node state transitions in case RTEMS_DEBUG is
defined.
Do not allocate the scheduler control structures from the workspace.
This is a preparation step for configuration of clustered/partitioned
schedulers on SMP.
Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Delete global variables _Priority_Major_bit_map and _Priority_Bit_map.
This makes it possible to use multiple priority scheduler instances for
example with clustered/partitioned scheduling on SMP.
Move workspace allocation to _Scheduler_priority_Initialize().
Remove superfluous check since a ready thread must exist.
Add and use _Scheduler_priority_Get_ready_queues()
Add and use _Scheduler_priority_Get_scheduler_info().
Add call to _Scheduler_Schedule() in missing path after
_Thread_Set_transient() in _Thread_Change_priority(). See also
sptests/spintrcritical19.
Add thread parameter to _Scheduler_Schedule(). This parameter is
currently unused but may be used in future SMP schedulers.
Do heir selection in _Scheduler_Schedule(). Use
_Scheduler_Update_heir() for this in the particular scheduler
implementation.
Add and use _Scheduler_Generic_block().
application visible API.
Move implementation specific parts of prioritybitmap.h and
prioritybitmap.inl into new header file prioritybitmapimpl.h. The
prioritybitmap.h contains now only the application visible API.
Move content of bitfield.h into prioritybitmapimpl.h.
Move implementation specific parts of schedulerpriority.h and
schedulerpriority.inl into new header file schedulerpriorityimpl.h. The
schedulerpriority.h contains now only the application visible API.
Add missing includes. Remove superfluous includes.
Move declaration of _Priority_Bit_map to prioritybitmap.inl since this
variable is used only here.
Remove second declaration of _Priority_Major_bit_map.
