path: root/cpukit/score/include/rtems/score/schedulernodeimpl.h (follow)
* score: Delete Scheduler_Node::accepts_helpSebastian Huber2016-11-021-1/+0
| | | | Update #2556.
* score: Second part of new MrsP implementationSebastian Huber2016-11-021-1/+0
| | | | Update #2556.
* score: Add _Scheduler_Node_get_scheduler()Sebastian Huber2016-11-021-0/+8
| | | | Update #2556.
* score: Manage scheduler nodes via thread queuesSebastian Huber2016-09-211-0/+1
| | | | Update #2556.
* score: Rework thread priority managementSebastian Huber2016-09-211-7/+12
| | | | | | | | | | | | | | | | | | | | | | | | | Add priority nodes which contribute to the overall thread priority. The actual priority of a thread is now an aggregation of priority nodes. The thread priority aggregation for the home scheduler instance of a thread consists of at least one priority node, which is normally the real priority of the thread. The locking protocols (e.g. priority ceiling and priority inheritance), rate-monotonic period objects and the POSIX sporadic server add, change and remove priority nodes. A thread changes its priority now immediately, e.g. priority changes are not deferred until the thread releases its last resource. Replace the _Thread_Change_priority() function with * _Thread_Priority_perform_actions(), * _Thread_Priority_add(), * _Thread_Priority_remove(), * _Thread_Priority_change(), and * _Thread_Priority_update(). Update #2412. Update #2556.
* score: Add scheduler node implementation headerSebastian Huber2016-09-081-0/+134
Update #2556.
