Scheduler operations must be free of a global scheduler context to
enable partitioned/clustered scheduling.
Delete _Scheduler_priority_Tick(). Use _SMP_Get_processor_count() for
default tick operation. Delete _Scheduler_simple_smp_Tick().
Add and use _Scheduler_Start_idle().
The output of the modules.html is much improved. Most
filesystem and POSIX API related groups are properly nested.
Some formatting issues were addressed as were multiple
inconsistencies.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
http://www.google-melange.com/gci/task/view/google/gci2012/7976215
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
Due to the fact that CBS extends the EDF scheduler, most parts of EDF are
reused. One part is the allocation of the per-thread data. However, the CBS
per-thread structure defines a further element (while including the rest of
Scheduler_EDF_Per_thread)
PR 1922
* score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c:
EDF and CBS scheduler: extern declarations fix.
PR 1906/cpukit
* sapi/Makefile.am, sapi/preinstall.am, sapi/include/confdefs.h,
score/Makefile.am, score/preinstall.am: Add the CBS (Constant
Bandwidth Server) scheduler. This is a complex scheduling policy
built atop of the EDF scheduler. Unlike other schedulers, this one
provides a user API and handles not only deadlines of tasks but also
claimed budget per period. The main aim of the scheduler is isolation
of tasks so that each task is guaranteed to meet all deadlines
regardless of how other tasks behave.
* sapi/include/rtems/cbs.h, sapi/inline/rtems/cbs.inl,
score/include/rtems/score/schedulercbs.h, score/src/schedulercbs.c,
score/src/schedulercbsattachthread.c,
score/src/schedulercbscleanup.c,
score/src/schedulercbscreateserver.c,
score/src/schedulercbsdestroyserver.c,
score/src/schedulercbsdetachthread.c,
score/src/schedulercbsgetapprovedbudget.c,
score/src/schedulercbsgetexecutiontime.c,
score/src/schedulercbsgetparameters.c,
score/src/schedulercbsgetremainingbudget.c,
score/src/schedulercbsgetserverid.c,
score/src/schedulercbsreleasejob.c,
score/src/schedulercbssetparameters.c,
score/src/schedulercbsunblock.c: New files.
