Thread dispatching is disabled in case interrupts are disabled. To get
an accurate thread dispatch disabled time it is important to use the
interrupt disabled instant in case a transition from an interrupt
disabled section to a thread dispatch level section happens.
Use "cpu" for an arbitrary Per_CPU_Control variable.
Use "cpu_self" for the Per_CPU_Control of the current processor.
Use "cpu_index" for an arbitrary processor index.
Use "cpu_index_self" for the processor index of the current processor.
Use "cpu_count" for the processor count obtained via
_SMP_Get_processor_count().
Use "cpu_max" for the processor maximum obtained by
rtems_configuration_get_maximum_processors().
Add per-CPU profiling stats API. Implement the thread dispatch disable
level profiling. The interrupt profiling must be implemented in CPU
port specific parts (mostly assembler code). Add a support function
_Profiling_Outer_most_interrupt_entry_and_exit() for this purpose.
