application visible API.
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/8013204
http://www.google-melange.com/gci/task/view/google/gci2012/7983216
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
http://www.google-melange.com/gci/task/view/google/gci2012/7970221
https://google-melange.appspot.com/gci/task/view/google/gci2012/7986214
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
http://www.google-melange.com/gci/task/view/google/gci2012/7982215
http://www.google-melange.com/gci/task/view/google/gci2012/7986213
https://google-melange.appspot.com/gci/task/view/google/gci2012/7978208
PR 1967/cpukit
* score/include/rtems/score/object.h,
score/src/objectinitializeinformation.c: Remove
OBJECTS_NAME_ALIGNMENT and uses.
* include/rtems/bspIo.h, include/rtems/concat.h,
include/rtems/endian.h, include/rtems/fs.h, include/rtems/irq.h,
include/rtems/pci.h, include/rtems/userenv.h,
libblock/include/rtems/flashdisk.h,
libblock/include/rtems/nvdisk-sram.h,
libblock/include/rtems/nvdisk.h, libcsupport/include/clockdrv.h,
libcsupport/include/console.h, libcsupport/include/iosupp.h,
libcsupport/include/spurious.h,
libcsupport/include/motorola/mc68230.h,
libcsupport/include/rtems/assoc.h, libcsupport/include/rtems/error.h,
libcsupport/include/rtems/framebuffer.h,
libcsupport/include/rtems/gxx_wrappers.h,
libcsupport/include/rtems/libcsupport.h,
libcsupport/include/rtems/libio_.h,
libcsupport/include/rtems/malloc.h,
libcsupport/include/rtems/termiostypes.h,
libcsupport/include/sys/statvfs.h, libcsupport/include/sys/termios.h,
libcsupport/include/sys/utsname.h, libcsupport/include/zilog/z8036.h,
libcsupport/include/zilog/z8530.h, libcsupport/include/zilog/z8536.h,
libfs/src/imfs/imfs.h, libfs/src/pipe/pipe.h,
libmisc/capture/capture-cli.h, libmisc/capture/capture.h,
libmisc/cpuuse/cpuuse.h, libmisc/devnull/devnull.h,
libmisc/devnull/devzero.h, libmisc/dumpbuf/dumpbuf.h,
libmisc/fb/fb.h, libmisc/fb/mw_uid.h, libmisc/mouse/mouse_parser.h,
libmisc/shell/shellconfig.h, libmisc/stringto/stringto.h,
libmisc/untar/untar.h, libnetworking/memory.h, posix/include/aio.h,
posix/include/mqueue.h, posix/include/semaphore.h,
posix/include/rtems/posix/aio_misc.h,
posix/include/rtems/posix/barrier.h,
posix/include/rtems/posix/cond.h, posix/include/rtems/posix/config.h,
posix/include/rtems/posix/key.h, posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/posixapi.h,
posix/include/rtems/posix/ptimer.h,
posix/include/rtems/posix/rwlock.h,
posix/include/rtems/posix/sigset.h,
posix/include/rtems/posix/spinlock.h,
posix/inline/rtems/posix/barrier.inl,
posix/inline/rtems/posix/rwlock.inl,
posix/inline/rtems/posix/spinlock.inl,
posix/inline/rtems/posix/timer.inl, rtems/mainpage.h,
rtems/include/rtems/rtems/barrier.h,
rtems/include/rtems/rtems/object.h,
rtems/include/rtems/rtems/timer.h,
rtems/inline/rtems/rtems/barrier.inl,
rtems/inline/rtems/rtems/timer.inl,
rtems/src/semtranslatereturncode.c, sapi/include/rtems/config.h,
sapi/include/rtems/fatal.h, sapi/include/rtems/mptables.h,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/priority.inl: Add @file Doxygen directives
and descriptions to files which originated with RTEMS. This improves
the file list page generated by Doxygen.
* Doxyfile.in, score/include/rtems/score/apimutex.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/object.h: Fix some Doxygen warnings.
PR 1660/filesystem
* libfs/src/pipe/fifo.c, libfs/src/pipe/pipe.h: Changed
int pipe_release to void pipe_release.
* libfs/src/imfs/imfs_fifo.c: Corresponding change to
IMFS_fifo_close since pipe_release does not return any error.
* libfs/src/imfs/imfs_initsupp.c: Changes to improve
IMFS_determine_bytes_per_block
* score/include/rtems/score/object.h: Remove OBJECTS_ITRON_API.
* core/include/rtems/score/object.h: Remove Objects_ITRON_API.
score/include/rtems/score/thread.h: Remove prototypes for ITRON
only methods removed by Ralf.
score/src/objectgetnameasstring.c, score/src/objectidtoname.c,
score/src/objectinitializeinformation.c,
score/src/objectnamespaceremove.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c, score/src/thread.c,
score/src/threadcreateidle.c: Disable object string name support when
POSIX is not enabled.
* libcsupport/src/free.c, libmisc/stackchk/check.c,
rtems/include/rtems/rtems/region.h, rtems/src/regioncreate.c,
rtems/src/regionextend.c, rtems/src/regiongetinfo.c,
rtems/src/regiongetsegment.c, rtems/src/regiongetsegmentsize.c,
rtems/src/regionresizesegment.c, score/src/pheapallocate.c,
score/src/pheapallocatealigned.c, score/src/pheapextend.c,
score/src/pheapfree.c, score/src/pheapgetblocksize.c,
score/src/pheapgetfreeinfo.c, score/src/pheapgetinfo.c,
score/src/pheapgetsize.c, score/src/pheapinit.c,
score/src/pheapresizeblock.c, score/src/pheapwalk.c:
Update for heap API changes.
* score/include/rtems/score/apimutex.h,
score/include/rtems/score/object.h: Documentation.
* score/include/rtems/score/heap.h,
score/include/rtems/score/protectedheap.h,
score/inline/rtems/score/heap.inl, score/src/heap.c,
score/src/heapallocate.c, score/src/heapallocatealigned.c,
score/src/heapextend.c, score/src/heapfree.c,
score/src/heapgetfreeinfo.c, score/src/heapgetinfo.c,
score/src/heapresizeblock.c, score/src/heapsizeofuserarea.c,
score/src/heapwalk.c: Overall cleanup. Added boundary constraint to
allocation function. More changes follow.
* libmisc/dummy/dummy-networking.c: New.
* libmisc/dummy/dummy.c, libmisc/Makefile.am: Move
trhe networking configuration into a separate file so
configuration varations do not cause conflicts.
* score/inline/rtems/score/object.inl,
score/include/rtems/score/object.h: Remove warnings.
* score/inline/rtems/score/object.inl: Add _Chain_First,
_Chain_Last, _Chain_Mext, and _Chain_Previous.
* sapi/inline/rtems/chain.inl: Add rtems_chain_first,
rtems_chain_last, rtems_chain_mext, and rtems_chain_previous.
* libblock/include/rtems/diskdevs.h: Remove the bdbuf pool id and
block_size_log2. Add media_block_size.
* libblock/src/diskdevs.c: Remove size restrictions on block
size. Add media block size initialisation. Remove comment to clean
up the bdbuf cache.
* libblock/src/blkdev.c: Remove references to
block_size_log2. Allow any block size.
* libblock/include/rtems/bdbuf.h, libblock/src/bdbuf.c: Remove all
references to pools and make the cache handle demand driver
variable buffer size allocation. Added worker threads support the
swapout task.
* sapi/include/confdefs.h: Updated the bdbuf configutation.
* rtems/src/rtemsobjectapimaximumclass.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c: Change
return type of API maximum class methods to unsigned.
* score/include/rtems/score/object.h: Maximum index if 0xffff not 0xff
when using 32-bit ids. This resulted in unlimited configurations not
being able to create more than 255 objects of a class.
score/src/objectallocatebyindex.c: Object index should be int.
Fix bug when index is negative.
* score/src/objectextendinformation.c: Do not allow maximum number
of allocated objects to exceed maximum representable in index
field of Object Id.
* score/src/objectgetisr.c: Use same code that is in _Objects_Get
to extract index field of Object Id.
* rtems/include/rtems/rtems/regionmp.h, sapi/include/rtems/config.h,
sapi/src/exinit.c, score/Makefile.am,
score/include/rtems/score/objectmp.h, score/src/objectmp.c: Eliminate
Object Handler Initialization routine since it was all for MP
configurations.
* score/src/object.c: Removed.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
PR 1265/cpukit
score/src/objectallocatebyindex.c: Rename index argument to avoid
warning when rtems.h and string.h are included at the same time by
user code.
and RTEMS_ID_NONE. No object can have this ID.
* posix/src/mqueueunlink.c, score/Makefile.am,
score/inline/rtems/score/object.inl: Enhance
_Objects_Namespace_remove() to handle freeing object names which are
strings. All changed _Objects_Close() to call
_Objects_Namespace_remove(). The resulting code was then moved from
inline routines to function calls.
* score/src/objectclose.c, score/src/objectnamespaceremove.c: New files.
* posix/src/cond.c, posix/src/key.c, posix/src/mqueuenametoid.c,
posix/src/mutex.c, posix/src/pbarrier.c, posix/src/prwlock.c,
posix/src/pspin.c, posix/src/pthread.c, posix/src/ptimer.c,
posix/src/semaphorenametoid.c: Add option for all POSIX objects
whether named or unnamed to have a string name. If the API does
not directly support having a name, then the user must explicitly
assign it using rtems_object_set_name().
* rtems/src/rtemsobjectgetapiclassname.c: Improved testability.
score/src/objectgetnameasstring.c, score/src/objectnametoidstring.c,
score/src/objectsetname.c: Modifications required to pass testing of
recently modified object name operations. Also eliminated
multiprocessing related code that was not reachable.
* score/include/rtems/score/object.h, score/src/objectgetinfo.c,
rtems/src/rtemsobjectgetapiclassname.c,
rtems/src/rtemsobjectgetclassinfo.c: class is a C++ keyword and
cannot be used as a parameter.
* score/Doxyfile: Update to latest Doxygen format.
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/heap.h, score/include/rtems/score/object.h,
score/include/rtems/score/threadsync.h,
score/inline/rtems/score/corerwlock.inl,
score/inline/rtems/score/corespinlock.inl: Remove most doxygen
warnings.
* itron/src/exd_tsk.c, itron/src/task.c, libmisc/capture/capture.c,
libmisc/monitor/mon-config.c, libmisc/monitor/mon-driver.c,
libmisc/monitor/mon-itask.c, libmisc/monitor/mon-monitor.c,
libmisc/monitor/mon-mpci.c, libmisc/monitor/mon-object.c,
libmisc/monitor/mon-symbols.c, posix/src/cancelrun.c,
posix/src/pthreadexit.c, rtems/Makefile.am, rtems/preinstall.am,
rtems/include/rtems.h, rtems/include/rtems/rtems/support.h,
rtems/inline/rtems/rtems/tasks.inl, rtems/src/eventmp.c,
rtems/src/msgmp.c, rtems/src/partmp.c, rtems/src/regionmp.c,
rtems/src/rtemsobjectgetname.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskdelete.c, rtems/src/taskmp.c,
rtems/src/timerserver.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/Unlimited.txt,
score/src/threadqextractwithproxy.c: Add new Object Services
collection. This changed the name of a few previously public but
undocumented services and added a some new services.
* rtems/include/rtems/rtems/object.h, rtems/src/rtemsbuildid.c,
rtems/src/rtemsbuildname.c, rtems/src/rtemsobjectapimaximumclass.c,
rtems/src/rtemsobjectapiminimumclass.c,
rtems/src/rtemsobjectgetapiname.c,
rtems/src/rtemsobjectgetclassicname.c,
rtems/src/rtemsobjectgetclassinfo.c,
rtems/src/rtemsobjectidapimaximum.c,
rtems/src/rtemsobjectidapiminimum.c, rtems/src/rtemsobjectidgetapi.c,
rtems/src/rtemsobjectidgetclass.c, rtems/src/rtemsobjectidgetindex.c,
rtems/src/rtemsobjectidgetnode.c, rtems/src/rtemsobjectsetname.c,
score/src/objectapimaximumclass.c, score/src/objectgetinfo.c,
score/src/objectgetinfoid.c, score/src/objectsetname.c: New files.
* rtems/src/rtemsidtoname.c: Removed.
score/src/objectextendinformation.c,
score/src/objectshrinkinformation.c: Eliminate name_table since it is
not used.
* itron/include/rtems/itron/object.h, itron/src/cre_tsk.c,
libblock/src/show_bdbuf.c, libmisc/capture/capture-cli.c,
libmisc/capture/capture.c, libmisc/monitor/mon-manager.c,
libmisc/stackchk/check.c, posix/src/condinit.c,
posix/src/keycreate.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuenametoid.c,
posix/src/mqueueopen.c, posix/src/mqueueunlink.c,
posix/src/mutexinit.c, posix/src/pbarrierinit.c,
posix/src/prwlockinit.c, posix/src/pspininit.c,
posix/src/pthreadcreate.c, posix/src/pthreadexit.c,
posix/src/semaphorecreatesupp.c, posix/src/semaphorenametoid.c,
posix/src/timercreate.c, rtems/src/barrierident.c,
rtems/src/dpmemident.c, rtems/src/msgqident.c, rtems/src/partident.c,
rtems/src/ratemonident.c, rtems/src/regionident.c,
rtems/src/semident.c, rtems/src/taskident.c, rtems/src/timerident.c,
sapi/src/extensionident.c, score/Makefile.am,
score/inline/rtems/score/object.inl, score/src/apimutexallocate.c,
score/src/objectgetnameasstring.c, score/src/objectmp.c,
score/src/objectnametoid.c: Convert the Objects_Name type from a
* score/src/objectclearname.c, score/src/objectcomparenameraw.c,
score/src/objectcopynamestring.c: Removed.
* sapi/src/exinit.c, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/src/object.c,
score/src/thread.c: Conditionally compile out more code that is
specific to multiprocessor configurations.
* itron/src/can_wup.c, itron/src/chg_pri.c, itron/src/del_mbf.c,
itron/src/del_mbx.c, itron/src/del_sem.c, itron/src/del_tsk.c,
itron/src/frsm_tsk.c, itron/src/ref_mbf.c, itron/src/ref_mbx.c,
itron/src/ref_sem.c, itron/src/ref_tsk.c, itron/src/rel_wai.c,
itron/src/rsm_tsk.c, itron/src/sig_sem.c, itron/src/snd_mbx.c,
itron/src/sta_tsk.c, itron/src/sus_tsk.c, itron/src/ter_tsk.c,
itron/src/trcv_mbf.c, itron/src/trcv_mbx.c, itron/src/tsnd_mbf.c,
itron/src/twai_sem.c, posix/src/cancel.c, posix/src/conddestroy.c,
posix/src/condinit.c, posix/src/condsignalsupp.c,
posix/src/condwaitsupp.c, posix/src/keydelete.c,
posix/src/keygetspecific.c, posix/src/keysetspecific.c,
posix/src/mqueueclose.c, posix/src/mqueuegetattr.c,
posix/src/mutexinit.c, posix/src/mutexlocksupp.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
posix/src/pbarrierdestroy.c, posix/src/pbarrierwait.c,
posix/src/prwlockdestroy.c, posix/src/prwlockrdlock.c,
posix/src/prwlocktryrdlock.c, posix/src/prwlocktrywrlock.c,
posix/src/prwlockunlock.c, posix/src/prwlockwrlock.c,
posix/src/pspindestroy.c, posix/src/pspinlock.c,
posix/src/pspintrylock.c, posix/src/pspinunlock.c,
posix/src/pthreaddetach.c, posix/src/pthreadequal.c,
posix/src/pthreadgetschedparam.c, posix/src/pthreadjoin.c,
posix/src/pthreadkill.c, posix/src/pthreadsetschedparam.c,
posix/src/ptimer1.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/types.c,
rtems/src/barrierdelete.c, rtems/src/barrierrelease.c,
rtems/src/barrierwait.c, rtems/src/dpmemdelete.c,
rtems/src/dpmemexternal2internal.c,
rtems/src/eventtimeout.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqgetnumberpending.c, rtems/src/msgqreceive.c,
rtems/src/msgqsend.c, rtems/src/msgqurgent.c, rtems/src/partdelete.c,
rtems/src/partgetbuffer.c, rtems/src/partreturnbuffer.c,
rtems/src/ratemoncancel.c, rtems/src/ratemondelete.c,
rtems/src/ratemongetstatistics.c, rtems/src/ratemongetstatus.c,
rtems/src/ratemontimeout.c, rtems/src/regiondelete.c,
rtems/src/regiongetsegmentsize.c, rtems/src/regionresizesegment.c,
rtems/src/regionreturnsegment.c, rtems/src/semdelete.c,
rtems/src/semflush.c, rtems/src/semobtain.c, rtems/src/semrelease.c,
rtems/src/signalsend.c, rtems/src/taskdelete.c,
rtems/src/taskgetnote.c, rtems/src/taskissuspended.c,
rtems/src/taskrestart.c, rtems/src/taskresume.c,
rtems/src/taskvariableadd.c, rtems/src/taskvariabledelete.c,
rtems/src/taskvariableget.c, rtems/src/timercancel.c,
rtems/src/timerserverfirewhen.c, sapi/src/extensiondelete.c,
score/include/rtems/score/object.h, score/src/corerwlocktimeout.c,
score/src/mpci.c, score/src/objectgetnameasstring.c,
score/src/threaddelayended.c, score/src/threadqtimeout.c: When
multiprocessing is disabled, do not even allow the constant
OBJECTS_REMOTE to appear in the source. Even at -O2, the presence of
a case OBJECTS_REMOTE in each id->pointer _Objects_Get switch results
in the generation of binary code which can NOT be reached.
