Move implementation specific parts of mpci.h into new header file
mpciimpl.h. The mpci.h contains now only the application visible API.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
Delete tqdata.h.
Move implementation specific parts of states.h and states.inl into new
header file statesimpl.h. The states.h contains now only the
comments in the RTEMS source.
http://www.google-melange.com/gci/task/view/google/gci2012/7985215
* rtems/include/rtems/rtems/types.h,
score/include/rtems/score/address.h,
score/include/rtems/score/apiext.h,
score/include/rtems/score/bitfield.h,
score/include/rtems/score/context.h,
score/include/rtems/score/corerwlock.h,
score/include/rtems/score/coresem.h,
score/include/rtems/score/corespinlock.h,
score/include/rtems/score/interr.h, score/include/rtems/score/isr.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h,
score/include/rtems/score/objectmp.h,
score/include/rtems/score/percpu.h,
score/include/rtems/score/rbtree.h,
score/include/rtems/score/scheduler.h,
score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h,
score/include/rtems/score/stack.h,
score/include/rtems/score/states.h,
score/include/rtems/score/threadq.h,
score/include/rtems/score/threadsync.h,
score/include/rtems/score/timespec.h,
score/include/rtems/score/timestamp.h,
score/include/rtems/score/timestamp64.h,
score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h,
score/include/rtems/score/watchdog.h,
score/include/rtems/score/wkspace.h: Mark Score files as in Score
Group to improve Doxygen output.
* libcsupport/include/rtems/malloc.h, libmisc/stackchk/stackchk.h,
posix/include/rtems/posix/time.h, rtems/include/rtems/rtems/object.h,
score/include/rtems/score/interr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/threadmp.h,
score/include/rtems/score/wkspace.h: Make @brief formatting more
consistent.
* score/include/rtems/score/rbtree.h: Also reformat.
* sapi/include/rtems/extension.h, sapi/include/rtems/io.h,
sapi/src/exinit.c, sapi/src/extension.c, sapi/src/io.c,
score/include/rtems/score/mpci.h, score/include/rtems/score/object.h,
score/include/rtems/score/thread.h, score/include/rtems/score/tod.h,
score/include/rtems/score/userext.h,
score/include/rtems/score/wkspace.h, score/src/coretod.c,
score/src/mpci.c, score/src/object.c, score/src/thread.c,
score/src/userext.c, score/src/wkspace.c: Convert SAPI manager and
SuperCore Handler initialization routines to directly pull parameters
from configuration table.
* score/include/rtems/score/mpci.h,
score/inline/rtems/score/threadmp.inl, score/src/mpci.c: Eliminate
dependencies between MP .h files.
* rtems/include/rtems/rtems/sem.h, rtems/src/semobtain.c:
Changed option set type to rtems_option.
* score/src/objectgetinfo.c: Check return value of
_Objects_API_maximum_class().
* libmisc/monitor/mon-mpci.c, libmisc/monitor/monitor.h,
rtems/include/rtems/rtems/message.h, rtems/src/msgmp.c,
rtems/src/msgqallocate.c, rtems/src/msgqbroadcast.c,
rtems/src/msgqcreate.c, rtems/src/msgqreceive.c, rtems/src/msgqsend.c,
rtems/src/msgqurgent.c, score/include/rtems/score/coremsg.h,
score/include/rtems/score/mpci.h, score/include/rtems/score/thread.h,
score/inline/rtems/score/coremsg.inl, score/src/coremsg.c,
score/src/coremsgbroadcast.c, score/src/coremsgseize.c,
score/src/coremsgsubmit.c:
Removed parameters of _Message_queue_Allocate(). Changed option set
type to rtems_option. Changed type of maximum message and packet size
to size_t. Changed the input buffer type for message send functions to
"const void *". Changed the pointer to the second return argument in
the thread wait information to a union. This union can contain a
pointer to an immutable or a mutable object. This is somewhat fragile.
An alternative would be to add a third pointer for immutable objects,
but this would increase the structure size.
* libcsupport/src/malloc.c, libmisc/monitor/mon-command.c,
posix/preinstall.am, posix/include/rtems/posix/cond.h,
posix/include/rtems/posix/mqueue.h,
posix/include/rtems/posix/mutex.h,
posix/include/rtems/posix/semaphore.h, posix/src/conddestroy.c,
posix/src/mutexdestroy.c, posix/src/mutexinit.c,
posix/src/mutexsetprioceiling.c, posix/src/mutexunlock.c,
sapi/include/confdefs.h, sapi/include/rtems/config.h,
sapi/include/rtems/init.h, sapi/include/rtems/sptables.h,
sapi/src/exinit.c, score/include/rtems/system.h,
score/include/rtems/score/mpci.h, score/src/mpci.c,
score/src/thread.c, score/src/threadcreateidle.c,
score/src/threadstackallocate.c, score/src/threadstackfree.c,
score/src/wkspace.c: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
Victor V. Vengerov <Victor.Vengerov@oktetlabs.ru>
score/macros/rtems/score/threadmp.inl, score/src/threadmp.c,
score/src/threadqenqueue.c: Victor spotted the problem that
_MPCI_Receive_server_tcb and _Thread_MP_Receive were duplicate
variables and needed to be set to the same value. I took that
idea and just removed _Thread_MP_Receive. All uses are now
_MPCI_Receive_server_tcb.
Large patch to improve Doxygen output. As a side-effect, grammar and
spelling errors were corrected, spacing errors were address, and some
variable names were improved.
* libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h:
Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS.
* score/Doxyfile: Set output directory. Predefine some macro values.
Turn on graphical output.
* score/include/rtems/debug.h, score/include/rtems/seterr.h,
score/include/rtems/system.h, score/include/rtems/score/address.h,
score/include/rtems/score/apimutex.h,
score/include/rtems/score/chain.h,
score/include/rtems/score/heap.h, score/include/rtems/score/interr.h,
score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h,
score/include/rtems/score/sysstate.h,
score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h,
score/inline/rtems/score/address.inl,
score/inline/rtems/score/chain.inl,
score/inline/rtems/score/coremutex.inl,
score/inline/rtems/score/coresem.inl,
score/inline/rtems/score/heap.inl,
score/inline/rtems/score/object.inl,
score/inline/rtems/score/stack.inl,
score/inline/rtems/score/thread.inl,
score/inline/rtems/score/tqdata.inl, score/macros/README,
score/src/heap.c, score/src/threadmp.c, score/src/threadready.c,
score/src/threadstartmultitasking.c: Improve generated Doxygen
output. Fix spelling and grammar errors in comments. Correct names of
some variables and propagate changes.
* score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h,
score/include/rtems/seterr.h, score/include/rtems/system.h,
score/include/rtems/score/copyrt.h,
score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl,
score/inline/rtems/score/mppkt.inl,
score/inline/rtems/score/objectmp.inl,
score/inline/rtems/score/priority.inl,
score/inline/rtems/score/states.inl,
score/inline/rtems/score/sysstate.inl,
score/inline/rtems/score/tod.inl,
score/inline/rtems/score/userext.inl,
score/inline/rtems/score/watchdog.inl,
score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working
modifications which are not complete and may have broken code.
Committing so work and testing can proceed.
* score/Doxyfile, score/mainpage.h: New files.
* score/include/rtems/debug.h, score/include/rtems/score/bitfield.h,
score/inline/rtems/score/wkspace.inl,
score/macros/rtems/score/address.inl,
score/macros/rtems/score/heap.inl,
score/macros/rtems/score/object.inl,
score/macros/rtems/score/priority.inl,
score/macros/rtems/score/userext.inl: Convert to using c99 fixed
size types.
the_class
the thread handler (IDLE), MPCI object (SYSI now MP Receive)
and initialize_executive_early (IO initialization). The SYSI task
no longer exists in a single processor configuration. This reduces
single processor Workspace requirements by a TCB and a stack which
is often larger than the minimum stack size. Moving the IO initialization
plus accompanying BSP hooks eliminated an initialization ordering problem
in which a global task could be created before the MPCI was initialized.
like signal dispatching.
