This is a preparation to remove the Giant lock.
Update #2555.
Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
Update #2555.
Rename _ISR_Disable_without_giant() into _ISR_Local_disable(). Rename
_ISR_Enable_without_giant() into _ISR_Local_enable().
Update #2555.
Thread dispatching is disabled in case interrupts are disabled. To get
an accurate thread dispatch disabled time it is important to use the
interrupt disabled instant in case a transition from an interrupt
disabled section to a thread dispatch level section happens.
Update #2273.
Empty structures are implementation-defined in C. GCC gives them a size
of zero. In C++ empty structures have a non-zero size.
Add ISR_LOCK_DEFINE() to define ISR locks for structures used by C and
C++.
Update #2273.
Add a local context structure to the SMP lock API for acquire and
release pairs. This context can be used to store the ISR level and
profiling information. It may be later used to enable more
sophisticated lock algorithms, e.g. MCS locks.
There is only one lock that cannot be used with a local context. This
is the per-CPU lock since here we would have to transfer the local
context through a context switch which is very complicated.
ISR locks are low-level locks to protect critical sections accessed by
threads and interrupt service routines.
On single processor configurations the ISR locks degrade to simple ISR
disable/enable sequences. No additional storage or objects are
required.
This synchronization primitive is supported on SMP configurations. Here
SMP locks are used.
