Rename _ISR_Disable() into _ISR_Local_disable(). Rename _ISR_Enable()
into _ISR_Local_enable(). Remove _Debug_Is_owner_of_giant().
This is a preparation to remove the Giant lock.
Update #2555.
Do not obfuscate the standard API.
Close #2286.
See also:
https://nahratzah.wordpress.com/2012/10/12/a-trivial-fair-spinlock/
http://concurrencyfreaks.blogspot.de/2014/05/relaxed-atomics-optimizations-for.html
Make <rtems/score/atomic.h> available for all RTEMS configurations. Use
inline functions instead of macros. Use ISR disable/enable on
uni-processor configurations to ensure atomicity.
Update #2273.
The GCC 4.9 ships its own <stdatomic.h> which is not C++ compatible.
The suggested solution was to include <atomic> in case C++ is used.
This works at least with GCC 4.9. See also:
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60932
http://gcc.gnu.org/bugzilla/show_bug.cgi?id=60940
The _Scheduler_SMP_Allocate_processor() and _Thread_Dispatch() exchange
information without locks. Make sure we use the right load/store
ordering.
Use unsigned long instead of uint_fast32_t since C11 provides only a
ATOMIC_LONG_LOCK_FREE macro constant. This makes it also possible to
use properly typed integer literals like 123UL. It is now clear which
compatible type should be used for the atomic integer.
Delete _Atomic_Init_flag(). Change ATOMIC_INITIALIZER_FLAG into a
constant. Rename _Atomic_Clear_flag() to _Atomic_Flag_clear(). Rename
_Atomic_Test_set_flag() to _Atomic_Flag_test_and_set(). This is now in
line with the C11 schema.
This file uses already C11 features. Include proper header file.
