Unify the status codes of the Classic and POSIX API to use the new enum
Status_Control. This eliminates the Thread_Control::Wait::timeout_code
field and the timeout parameter of _Thread_queue_Enqueue_critical() and
_MPCI_Send_request_packet(). It gets rid of the status code translation
tables and instead uses simple bit operations to get the status for a
particular API. This enables translation of status code constants at
compile time. Add _Thread_Wait_get_status() to avoid direct access of
thread internal data structures.
Drop the multiprocessing (MP) dependent callout parameter from the
thread queue extract, dequeue, flush and unblock methods. Merge this
parameter with the lock context into new structure Thread_queue_Context.
This helps to gets rid of the conditionally compiled method call
helpers.
Get rid of the mp_id parameter used for some thread queue methods. Use
THREAD_QUEUE_QUEUE_TO_OBJECT() instead.
Bug introduced by f27383a518836881b7b9b88e88d2e31d5b23d048.
Use _Thread_queue_Flush_critical() to atomically release the barrier.
Update #2555.
Rename _CORE_barrier_Wait() into _CORE_barrier_Seize(). Rename
_CORE_barrier_Release() into _CORE_barrier_Surrender(). This avoids
confusion with the ISR lock acquire and release.
Replace _Thread_queue_Flush() with _Thread_queue_Flush_critical() and
add a filter function for customization of the thread queue flush
operation.
Update #2555.
The thread queue implementation was heavily reworked to support SMP.
This broke the multiprocessing support of the thread queues. This is
fixed by this patch.
A thread proxy is unblocked due to three reasons
1) timeout,
2) request satisfaction, and
3) extraction.
In case 1) no MPCI message must be sent. This is ensured via the
_Thread_queue_MP_callout_do_nothing() callout set during
_Thread_MP_Allocate_proxy().
In case 2) and 3) an MPCI message must be sent. In case we interrupt
the blocking operation during _Thread_queue_Enqueue_critical(), then
this message must be sent by the blocking thread. For this the new
fields Thread_Proxy_control::thread_queue_callout and
Thread_Proxy_control::thread_queue_id are used.
Delete the individual API MP callout types and use
Thread_queue_MP_callout throughout. This type is only defined in
multiprocessing configurations. Prefix the multiprocessing parameters
with mp_ to ease code review. Multiprocessing specific parameters are
optional due to use of a similar macro pattern. There is no overhead
for non-multiprocessing configurations.
Change _Thread_queue_Flush() into a macro that invokes
_Thread_queue_Do_flush() with the parameter set defined by
RTEMS_MULTIPROCESSING. For multiprocessing configurations add the
object identifier to avoid direct use of the thread wait information.
Use mp_ prefix for multiprocessing related parameters.
Rename Thread_queue_Flush_callout to Thread_queue_MP_callout since this
type will be re-used later for other operations as well.
Remove the Thread_queue_Queue::operations field to reduce the size of
this structure. Add a thread queue operations parameter to the
_Thread_queue_First(), _Thread_queue_First_locked(),
_Thread_queue_Enqueue(), _Thread_queue_Dequeue() and
_Thread_queue_Flush() functions. This is a preparation patch to reduce
the size of several synchronization objects.
Move the complete thread queue enqueue procedure into
_Thread_queue_Enqueue_critical(). It is possible to use the thread
queue lock to protect state of the object embedding the thread queue.
This enables per object fine grained locking in the future.
Delete _Thread_queue_Enter_critical_section().
Update #2273.
Move implementation specific parts of tqdata.h, threadq.h and
threadq.inl into new header file threadqimpl.h. The threadq.h contains
now only the application visible API.
Delete tqdata.h.
Pass the executing thread as a function parameter. Obtain the executing
thread inside a thread dispatch critical section to avoid problems on
SMP.
Move implementation specific parts of corebarrier.h and corebarrier.inl
into new header file corebarrierimpl.h. The corebarrier.h contains now
