path: root/cpukit/score/include/rtems/score/context.h (follow)
* Added Sporadic Server support to posix threads which required changesJoel Sherrill1996-06-061-1/+1
| | | | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize. Makde _Context_Switch_necessary volatile.
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-1/+1
| | | | score, rtems api, or posix api related.
* SPARC port passes all testsJoel Sherrill1995-10-301-2/+3
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+133
