path: root/cpukit/score/include/rtems/score/context.h (follow)
* score: _CPU_Context_switch_to_first_task_smp()Sebastian Huber2014-02-051-17/+0
| | | | | Delete _CPU_Context_switch_to_first_task_smp() and use _CPU_Context_restore() instead.
* Add thread-local storage (TLS) supportSebastian Huber2014-02-041-2/+5
| | | | | Tested and implemented on ARM, m68k, PowerPC and SPARC. Other architectures need more work.
* cpukit: Add EOL on files missing EOL at EOFJoel Sherrill2013-01-101-1/+1
* score: Doxygen Clean Up Task #1Mathew Kallada2012-12-291-11/+13
* 2011-06-17 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-06-171-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * rtems/include/rtems/rtems/types.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/context.h, score/include/rtems/score/corebarrier.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/corerwlock.h, score/include/rtems/score/coresem.h, score/include/rtems/score/corespinlock.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/percpu.h, score/include/rtems/score/priority.h, score/include/rtems/score/rbtree.h, score/include/rtems/score/scheduler.h, score/include/rtems/score/smp.h, score/include/rtems/score/smplock.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadq.h, score/include/rtems/score/threadsync.h, score/include/rtems/score/timespec.h, score/include/rtems/score/timestamp.h, score/include/rtems/score/timestamp64.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h: Mark Score files as in Score Group to improve Doxygen output.
* 2011-03-16 Jennifer Averett <jennifer.averett@OARcorp.com>Joel Sherrill2011-03-161-0/+17
| | | | | | | | | | | | | | | | | | | | | | PR 1729/cpukit * configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c, score/Makefile.am, score/preinstall.am, score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S, score/cpu/sparc/rtems/score/cpu.h, score/include/rtems/score/basedefs.h, score/include/rtems/score/context.h, score/include/rtems/score/percpu.h, score/src/percpu.c, score/src/thread.c, score/src/threadcreateidle.c: Add next step in SMP support. This adds an allocated array of the Per_CPU structures to support multiple cpus vs a single instance of the structure which is still used if SMP support is disabled. Configuration support is also added to explicitly enable or disable SMP. But SMP can only be enabled for the CPUs which will support it initially -- SPARC and i386. With the stub BSP support, a BSP can be run as a single core SMP system from an RTEMS data structure standpoint. * aclocal/check-smp.m4, aclocal/enable-smp.m4, score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h, score/src/smp.c, score/src/smplock.c: New files.
* 2011-02-11 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-02-111-1/+2
| | | | * score/include/rtems/score/context.h: Spacing.
* 2010-06-28 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-06-291-10/+3
| | | | | | | | | | | | | | | | | | | PR 1573/cpukit * configure.ac, posix/src/killinfo.c, posix/src/psignalclearprocesssignals.c, posix/src/psignalsetprocesssignals.c, posix/src/psignalunblockthread.c, posix/src/pthreadcreate.c, posix/src/pthreadkill.c, posix/src/pthreadsigmask.c, rtems/src/signalsend.c, rtems/src/taskmode.c, score/Makefile.am, score/preinstall.am, score/include/rtems/system.h, score/include/rtems/score/context.h, score/include/rtems/score/isr.h, score/include/rtems/score/thread.h, score/src/isr.c, score/src/isrthreaddispatch.c, score/src/thread.c, score/src/threaddispatch.c, score/src/threadloadenv.c: Add a per cpu data structure which contains the information required by RTEMS for each CPU core. This encapsulates information such as thread executing, heir, idle and dispatch needed. * score/include/rtems/score/percpu.h, score/src/percpu.c: New files.
* Whitespace removal.Ralf Corsepius2009-11-281-2/+2
* Eliminate TRUE/FALSE.Ralf Corsepius2008-12-221-2/+2
* Convert to "bool".Ralf Corsepius2008-09-041-1/+1
* 2007-11-02 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-11-021-0/+16
| | | | | | | | * score/cpu/sparc/cpu.c, score/cpu/sparc/rtems/score/cpu.h, score/include/rtems/score/context.h, score/src/threadhandler.c: Fix stack so gdb backtrace does not print corrupted frame message after _Thread_Handler. Daniel Hellstrom <daniel@gaisler.com> provided the SPARC implementation and I made it more general.
* 2006-01-16 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2006-01-161-27/+34
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Large patch to improve Doxygen output. As a side-effect, grammar and spelling errors were corrected, spacing errors were address, and some variable names were improved. * libmisc/monitor/mon-object.c, libmisc/monitor/monitor.h: Account for changing OBJECTS_NO_CLASS to OBJECTS_CLASSIC_NO_CLASS. * score/Doxyfile: Set output directory. Predefine some macro values. Turn on graphical output. * score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/object.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/object.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/tqdata.inl, score/macros/README, score/src/heap.c, score/src/threadmp.c, score/src/threadready.c, score/src/threadstartmultitasking.c: Improve generated Doxygen output. Fix spelling and grammar errors in comments. Correct names of some variables and propagate changes.
* New header guard.Ralf Corsepius2005-01-281-2/+2
* Adjust doxygen @file.Ralf Corsepius2004-11-211-1/+1
* 2004-11-01 Joel Sherrill <joel@oarcorp.com>Joel Sherrill2004-11-011-56/+69
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * score/cpu/no_cpu/rtems/score/cpu.h, score/include/rtems/debug.h, score/include/rtems/seterr.h, score/include/rtems/system.h, score/include/rtems/score/address.h, score/include/rtems/score/apiext.h, score/include/rtems/score/apimutex.h, score/include/rtems/score/bitfield.h, score/include/rtems/score/chain.h, score/include/rtems/score/context.h, score/include/rtems/score/copyrt.h, score/include/rtems/score/coremsg.h, score/include/rtems/score/coremutex.h, score/include/rtems/score/coresem.h, score/include/rtems/score/heap.h, score/include/rtems/score/interr.h, score/include/rtems/score/isr.h, score/include/rtems/score/mpci.h, score/include/rtems/score/mppkt.h, score/include/rtems/score/objectmp.h, score/include/rtems/score/priority.h, score/include/rtems/score/stack.h, score/include/rtems/score/states.h, score/include/rtems/score/sysstate.h, score/include/rtems/score/thread.h, score/include/rtems/score/threadmp.h, score/include/rtems/score/threadq.h, score/include/rtems/score/tod.h, score/include/rtems/score/tqdata.h, score/include/rtems/score/userext.h, score/include/rtems/score/watchdog.h, score/include/rtems/score/wkspace.h, score/inline/rtems/score/address.inl, score/inline/rtems/score/chain.inl, score/inline/rtems/score/coremsg.inl, score/inline/rtems/score/coremutex.inl, score/inline/rtems/score/coresem.inl, score/inline/rtems/score/heap.inl, score/inline/rtems/score/isr.inl, score/inline/rtems/score/mppkt.inl, score/inline/rtems/score/objectmp.inl, score/inline/rtems/score/priority.inl, score/inline/rtems/score/stack.inl, score/inline/rtems/score/states.inl, score/inline/rtems/score/sysstate.inl, score/inline/rtems/score/thread.inl, score/inline/rtems/score/threadmp.inl, score/inline/rtems/score/tod.inl, score/inline/rtems/score/tqdata.inl, score/inline/rtems/score/userext.inl, score/inline/rtems/score/watchdog.inl, score/inline/rtems/score/wkspace.inl: Add Doxygen comments -- working modifications which are not complete and may have broken code. Committing so work and testing can proceed. * score/Doxyfile, score/mainpage.h: New files.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-041-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/rtems/debug.h, include/rtems/seterr.h, include/rtems/system.h, include/rtems/score/address.h, include/rtems/score/apiext.h, include/rtems/score/apimutex.h, include/rtems/score/bitfield.h, include/rtems/score/chain.h, include/rtems/score/context.h, include/rtems/score/copyrt.h, include/rtems/score/coremsg.h, include/rtems/score/coremutex.h, include/rtems/score/coresem.h, include/rtems/score/heap.h, include/rtems/score/interr.h, include/rtems/score/isr.h, include/rtems/score/mpci.h, include/rtems/score/mppkt.h, include/rtems/score/object.h, include/rtems/score/objectmp.h, include/rtems/score/priority.h, include/rtems/score/stack.h, include/rtems/score/states.h, include/rtems/score/sysstate.h, include/rtems/score/thread.h, include/rtems/score/threadmp.h, include/rtems/score/threadq.h, include/rtems/score/tod.h, include/rtems/score/tqdata.h, include/rtems/score/userext.h, include/rtems/score/watchdog.h, include/rtems/score/wkspace.h, inline/rtems/score/address.inl, inline/rtems/score/chain.inl, inline/rtems/score/coremsg.inl, inline/rtems/score/coremutex.inl, inline/rtems/score/coresem.inl, inline/rtems/score/heap.inl, inline/rtems/score/isr.inl, inline/rtems/score/mppkt.inl, inline/rtems/score/object.inl, inline/rtems/score/objectmp.inl, inline/rtems/score/priority.inl, inline/rtems/score/stack.inl, inline/rtems/score/states.inl, inline/rtems/score/sysstate.inl, inline/rtems/score/thread.inl, inline/rtems/score/threadmp.inl, inline/rtems/score/tod.inl, inline/rtems/score/tqdata.inl, inline/rtems/score/userext.inl, inline/rtems/score/watchdog.inl, inline/rtems/score/wkspace.inl, macros/rtems/score/address.inl, macros/rtems/score/chain.inl, macros/rtems/score/coremsg.inl, macros/rtems/score/coremutex.inl, macros/rtems/score/coresem.inl, macros/rtems/score/heap.inl, macros/rtems/score/isr.inl, macros/rtems/score/mppkt.inl, macros/rtems/score/object.inl, macros/rtems/score/objectmp.inl, macros/rtems/score/priority.inl, macros/rtems/score/stack.inl, macros/rtems/score/states.inl, macros/rtems/score/sysstate.inl, macros/rtems/score/thread.inl, macros/rtems/score/threadmp.inl, macros/rtems/score/tod.inl, macros/rtems/score/tqdata.inl, macros/rtems/score/userext.inl, macros/rtems/score/watchdog.inl, macros/rtems/score/wkspace.inl, src/apiext.c, src/chain.c, src/coremsg.c, src/coremsgbroadcast.c, src/coremsgclose.c, src/coremsgflush.c, src/coremsgflushsupp.c, src/coremsgflushwait.c, src/coremsginsert.c, src/coremsgseize.c, src/coremsgsubmit.c, src/coremutex.c, src/coremutexflush.c, src/coremutexseize.c, src/coremutexsurrender.c, src/coresem.c, src/coresemflush.c, src/coresemseize.c, src/coresemsurrender.c, src/coretod.c, src/coretodset.c, src/coretodtickle.c, src/coretodtoseconds.c, src/coretodvalidate.c, src/heap.c, src/heapallocate.c, src/heapextend.c, src/heapfree.c, src/heapgetinfo.c, src/heapsizeofuserarea.c, src/heapwalk.c, src/interr.c, src/isr.c, src/iterateoverthreads.c, src/mpci.c, src/object.c, src/objectallocate.c, src/objectallocatebyindex.c, src/objectclearname.c, src/objectcomparenameraw.c, src/objectcomparenamestring.c, src/objectcopynameraw.c, src/objectcopynamestring.c, src/objectextendinformation.c, src/objectfree.c, src/objectget.c, src/objectgetbyindex.c, src/objectgetisr.c, src/objectgetnext.c, src/objectgetnoprotection.c, src/objectidtoname.c, src/objectinitializeinformation.c, src/objectmp.c, src/objectnametoid.c, src/objectshrinkinformation.c, src/thread.c, src/threadchangepriority.c, src/threadclearstate.c, src/threadclose.c, src/threadcreateidle.c, src/threaddelayended.c, src/threaddispatch.c, src/threadevaluatemode.c, src/threadget.c, src/threadhandler.c, src/threadidlebody.c, src/threadinitialize.c, src/threadloadenv.c, src/threadmp.c, src/threadq.c, src/threadqdequeue.c, src/threadqdequeuefifo.c, src/threadqdequeuepriority.c, src/threadqenqueue.c, src/threadqenqueuefifo.c, src/threadqenqueuepriority.c, src/threadqextract.c, src/threadqextractfifo.c, src/threadqextractpriority.c, src/threadqextractwithproxy.c, src/threadqfirst.c, src/threadqfirstfifo.c, src/threadqfirstpriority.c, src/threadqflush.c, src/threadqtimeout.c, src/threadready.c, src/threadreset.c, src/threadresettimeslice.c, src/threadrestart.c, src/threadresume.c, src/threadrotatequeue.c, src/threadsetpriority.c, src/threadsetstate.c, src/threadsettransient.c, src/threadstackallocate.c, src/threadstackfree.c, src/threadstart.c, src/threadstartmultitasking.c, src/threadsuspend.c, src/threadtickletimeslice.c, src/threadyieldprocessor.c, src/userext.c, src/watchdog.c, src/watchdogadjust.c, src/watchdoginsert.c, src/watchdogremove.c, src/watchdogtickle.c, src/wkspace.c: URL for license changed.
* Added Sporadic Server support to posix threads which required changesJoel Sherrill1996-06-061-1/+1
| | | | | | | in the core to support multiple algorithms to handle cpu time budgetting which resulted in a change to the calling sequence of _Thread_Initialize. Makde _Context_Switch_necessary volatile.
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-1/+1
| | | | score, rtems api, or posix api related.
* SPARC port passes all testsJoel Sherrill1995-10-301-2/+3
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-1/+1
* Initial revisionJoel Sherrill1995-05-111-0/+133
