* | score: Add _Chain_Initialize_one() | Sebastian Huber | 2016-09-06 | 1 | -0/+27 |
* | score: Add missing const qualifiers | Sebastian Huber | 2016-09-06 | 1 | -6/+6 |
* | score: Add debug support to chains | Sebastian Huber | 2016-07-22 | 1 | -5/+47 |
| | | | | | | | This helps to detect * double insert, append, prepend errors, and * get from empty chain errors. | ||||
* | score: Add Chain_Iterator | Sebastian Huber | 2016-04-18 | 1 | -0/+239 |
| | | | | | Add a chain iterator for safe iteration of chains with concurrent node extraction. | ||||
* | score: Delete _Chain_Append() | Sebastian Huber | 2016-04-06 | 1 | -13/+0 |
| | | | | | | This function is not used in the score. Update #2555. | ||||
* | score: Delete _Chain_Get() | Sebastian Huber | 2016-04-06 | 1 | -16/+0 |
* | score: Delete _Chain_Extract() | Sebastian Huber | 2016-04-06 | 1 | -15/+0 |
* | score: Delete _Chain_Insert() | Sebastian Huber | 2016-04-06 | 1 | -21/+0 |
* | score: Delete _Chain_Get_with_empty_check() | Sebastian Huber | 2016-04-06 | 1 | -25/+0 |
* | score: Delete _Chain_Prepend_with_empty_check() | Sebastian Huber | 2016-04-06 | 1 | -19/+0 |
* | score: Delete _Chain_Append_with_empty_check() | Sebastian Huber | 2016-04-06 | 1 | -19/+0 |
* | score: Delete _Chain_Prepend() | Sebastian Huber | 2016-04-06 | 1 | -19/+0 |
* | chainimpl.h: Add _Assert() to _Chain_Initialize_empty() | Josh Oguin | 2014-11-26 | 1 | -3/+9 |
| | | | | | CodeSonar flagged this as a potential NULL deference. That should never occur but adding the _Assert() ensures we are checking that. | ||||
* | Delete unused *_Is_null() functions | Sebastian Huber | 2014-07-26 | 1 | -17/+0 |
* | score: Use only next field for chain on/off | Sebastian Huber | 2014-03-17 | 1 | -6/+6 |
| | | | | | It is sufficient to use one field for the chain on/off indication. The chain API functions are highly performance critical. | ||||
* | score: Add and use CHAIN_INITIALIZER_ONE_NODE(). | Sebastian Huber | 2013-08-27 | 1 | -0/+16 |
| | | | | | | Add and use CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(), RTEMS_CHAIN_INITIALIZER_ONE_NODE() and RTEMS_CHAIN_NODE_INITIALIZER_ONE_NODE_CHAIN(). | ||||
* | score: Create chain implementation header | Sebastian Huber | 2013-07-22 | 1 | -0/+952 |
Move implementation specific parts of chain.h and chain.inl into new header file chainimpl.h. The chain.h contains now only the application visible API. |
