Rename _Internal_error_Occurred() into _Terminate().
* score/include/rtems/score/basedefs.h: Typo.
* score/src/mpci.c, rtems/src/eventmp.c, rtems/src/msgmp.c,
rtems/src/partmp.c, rtems/src/regionmp.c, rtems/src/semmp.c,
rtems/src/signalmp.c, rtems/src/taskmp.c: Use RTEMS_STATIC_ASSERT() to
ensure that the packet size is small enough.
PR 1842/cpukit
* score/include/rtems/score/basedefs.h: Added RTEMS_STATIC_ASSERT().
* Doxyfile.in, score/include/rtems/score/apimutex.h,
score/include/rtems/score/basedefs.h,
score/include/rtems/score/object.h: Fix some Doxygen warnings.
PR 1729/cpukit
* configure.ac, sapi/include/confdefs.h, sapi/src/exinit.c,
score/Makefile.am, score/preinstall.am,
score/cpu/i386/rtems/score/cpu.h, score/cpu/sparc/cpu_asm.S,
score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/context.h,
score/include/rtems/score/percpu.h, score/src/percpu.c,
score/src/thread.c, score/src/threadcreateidle.c: Add next step in
SMP support. This adds an allocated array of the Per_CPU structures
to support multiple cpus vs a single instance of the structure which
is still used if SMP support is disabled. Configuration support is
also added to explicitly enable or disable SMP. But SMP can only be
enabled for the CPUs which will support it initially -- SPARC and
i386. With the stub BSP support, a BSP can be run as a single core
SMP system from an RTEMS data structure standpoint.
* aclocal/check-smp.m4, aclocal/enable-smp.m4,
score/include/rtems/bspsmp.h, score/include/rtems/score/smplock.h,
score/src/smp.c, score/src/smplock.c: New files.
* score/include/rtems/score/basedefs.h: New file.
* score/Makefile.am, score/preinstall.am: Reflect change above.
* score/include/rtems/score/percpu.h: Include <rtems/score/cpu.h>.
* score/include/rtems/system.h: Moved definition of SCORE_EXTERN,
SAPI_EXTERN, RTEMS_EXTERN, POSIX_EXTERN, RTEMS_INLINE_ROUTINE,
RTEMS_COMPILER_MEMORY_BARRIER, RTEMS_COMPILER_NO_RETURN_ATTRIBUTE,
RTEMS_COMPILER_DEPRECATED_ATTRIBUTE, TRUE, and FALSE to
<rtems/score/basedefs.h>.
Removed include of <rtems/score/cpu.h>, <stdint.h> and <stddef.h>.
