- rtems/score/assert.h: Scheduler Simulator uses glibc assert.h on GNU/Linux.
This will likely need to be adjusted more for other host compilers and
C libraries. Also disable _Assert_Not_reached() because some of these
paths do actually return to the called on the Scheduler Simulator.
- basedefs.h: Do not use noreturn attribute when on Scheduler Simulator.
Paths which context switch can return to the command interpreter on
Add _Debug_Is_owner_of_giant(). This makes it possible to assert the
opposite.
Add _Debug_Is_thread_dispatching_allowed(). This makes it possible to
assert the opposite.
Use _ISR_Disable_without_giant()/_ISR_Enable_without_giant() to avoid
misleading secondary assertion failures.
Add and use _ISR_Disable_without_giant() and
_ISR_Enable_without_giant() if RTEMS_SMP is defined.
On single processor systems the ISR disable/enable was the big hammer
which ensured system-wide mutual exclusion. On SMP configurations this
no longer works since other processors do not care about disabled
interrupts on this processor and continue to execute freely.
On SMP in addition to ISR disable/enable an SMP lock must be used.
Currently we have only the Giant lock so we can check easily that ISR
disable/enable is used only in the right context.
