path: root/cpukit/score/include/rtems/score/apiext.h (follow)
* split the inclusion of "EXTERN" data based on whether it was sapi,Joel Sherrill1996-05-281-1/+1
| | | | score, rtems api, or posix api related.
* changed post task extension from user set to api set and added flagJoel Sherrill1996-02-131-3/+19
| | | | in each thread which must be set when the post switch extension is to be run.
* posix support initially addedJoel Sherrill1995-09-261-1/+1
* More file movement required api extension to be added to scoreJoel Sherrill1995-09-211-0/+86
