PR 1469/cpukit
* cpu.c: Add dummy entry for (non-existing) exception #15.
Otherwise all slots for vectors >= 16 are one element off.
PR 1385/cpukit
* cpu_asm.S: When the type rtems_boolean was switched to the C99 bool,
the size changed from 4 bytes to 1 byte. The interrupt dispatching
code accesses two boolean variables for scheduling purposes and the
assembly implementations of this code did not get updated.
* rtems/score/types.h: Do not define boolean, single_precision,
double_precision unless RTEMS_DEPRECATED_TYPES is given.
* score/cpu/c4x/.cvsignore, score/cpu/c4x/ChangeLog,
score/cpu/c4x/Makefile.am, score/cpu/c4x/cpu.c,
score/cpu/c4x/cpu_asm.S, score/cpu/c4x/irq.c,
score/cpu/c4x/preinstall.am, score/cpu/c4x/rtems/asm.h,
score/cpu/c4x/rtems/score/c4x.h, score/cpu/c4x/rtems/score/cpu.h,
score/cpu/c4x/rtems/score/cpu_asm.h,
score/cpu/c4x/rtems/score/types.h, score/cpu/c4x/rtems/tic4x/c4xio.h,
score/cpu/nios2/.cvsignore, score/cpu/nios2/ChangeLog,
score/cpu/nios2/Makefile.am, score/cpu/nios2/cpu.c,
score/cpu/nios2/cpu_asm.S, score/cpu/nios2/irq.c,
score/cpu/nios2/preinstall.am, score/cpu/nios2/rtems/asm.h,
score/cpu/nios2/rtems/score/cpu.h,
score/cpu/nios2/rtems/score/cpu_asm.h,
score/cpu/nios2/rtems/score/nios2.h,
score/cpu/nios2/rtems/score/types.h: Removed.
* configure.ac, aclocal/canonical-target-name.m4,
score/cpu/Makefile.am: Remove TI C4x and NIOS2 ports from 4.9 branch.
* cpu.c: Remove extraneous spaces.
* rtems/score/cpu.h: Remove extraneous spaces.
* cpu.c, rtems/score/cpu.h: Remove extraneous spaces.
* Makefile.am: Merge thumb/Makefile.am.
* thumb/Makefile.am: Remove (superfluous).
* cpu.c: Stop using old-style defs.
* cpu.c, rtems/score/cpu.h: Convert to "bool".
* rtems/new-exceptions/cpu.h, rtems/score/cpu.h: Convert to "bool".
* rtems/score/avr.h: Add avr25, avr31, avr35, avr51 to
CPU_NAME cascade.
* rtems/score/cpu.h: Add missing prototypes.h.
* rtems/score/types.h: Include stdbool.h.
Use bool as base-type for boolean.
* rtems/score/cpu.h: Correct prototype of _CPU_Thread_dispatch_pointer.
* cpu.c: Fix prototypes.
* rtems/score/cpu.h: Use memcpy() initialize FP structure and avoid
many casts and potential warnings.
* rtems/score/cpu.h: Fix type when initializing FP context.
* cpu.c, rtems/score/cpu.h: Add extern for bfffo table and rename it to
indicate that it is specific to this architecture.
* rtems/score/cpu.h: Add missing prototype.
* cpu.c, rtems/score/cpu.h: Add void.
* rtems/score/cpu.h, rtems/score/i386.h: Add missing prototypes.
* ChangeLog: Add correct entry.
* rtems/include/rtems/rtems/ratemon.h,
rtems/include/rtems/rtems/status.h,
score/include/rtems/score/object.h: Removed extraneous commas.
* rtems/powerpc/registers.h: Removed obsolete defines MSR_, MSR_KERNEL
and MSR_USER. Added missing prototypes.
* rtems/new-exceptions/cpu.h: Changed define
CPU_INTERRUPT_MAXIMUM_VECTOR_NUMBER to UINT32_MAX to avoid comparison
between signed and unsigned.
PR 1294/bsps
* rtems/score/cpu.h, rtems/score/sparc.h: Correct prototype and usage
of sparc_disable_interrupts.
* rtems/score/cpu.h: Spacing.
* cpu.c, rtems/score/cpu.h: Correct prototype of Idle threads.
* rtems/score/cpu.h: Correct prototype of Idle threads.
fixed some minors in mpc83xx support
added file for mpc55xx watchdog support
* score/cpu/powerpc/rtems/new-exceptions/cpu.h:
use ppc_interrupt_get_disable_mask() to determine
which bits to set/clear from _CPU_ISR_Set_level().
* score/cpu/powerpc/rtems/powerpc/registers.h:
added ppc_interrupt_get_disable_mask() inline function.
* cpukit/score/cpu/powerpc/rtems/new-exceptions/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/cpu.h,
cpukit/score/cpu/powerpc/rtems/score/powerpc.h:
Removed all macro definitions which depended on
the compiler defining a PPC CPU-model dependent
symbol.
Macros which were not used by cpukit have been
moved to libcpu/powerpc/rtems/powerpc/powerpc.h.
