* cpu.c, rtems/score/cpu.h: Move interrupt_stack_size field from CPU
Table to Configuration Table. Eliminate CPU Table from all ports.
Delete references to CPU Table in all forms.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h,
rtems/score/cpu.h: Move interrupt_stack_size field from CPU Table to
Configuration Table. Eliminate CPU Table from all ports. Delete
* rtems/score/cpu.h: Added comment that GDB patch sim/2376
is needed for reading the time-base with the new (more
portable) method.
* rtems/score/cpu.h: Moved most of the remaining CPU Table fields to
the Configuration Table. This included pretasking_hook,
predriver_hook, postdriver_hook, idle_task, do_zero_of_workspace,
extra_mpci_receive_server_stack, stack_allocate_hook, and
stack_free_hook. As a side-effect of this effort some multiprocessing
code was made conditional and some style clean up occurred.
* rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Moved most of
the remaining CPU Table fields to the Configuration Table. This
included pretasking_hook, predriver_hook, postdriver_hook, idle_task,
do_zero_of_workspace, extra_mpci_receive_server_stack,
stack_allocate_hook, and stack_free_hook. As a side-effect of this
effort some multiprocessing code was made conditional and some style
clean up occurred.
* rtems/score/cpu.h: Wonderful bookE doesn't have mftb/mftbu;
( CPU_Get_timebase_low() ) they only define the TBRU/TBRL SPRs
so we use these. Should work on all CPUs.
rtems/score/cpu.h: Eliminate PowerPC specific elements from the CPU
Table. They have been replaced with variables named bsp_XXX as
needed.
* posix/Makefile.am, posix/preinstall.am, posix/src/cancel.c,
posix/src/conddestroy.c, posix/src/condinit.c,
posix/src/condsignalsupp.c, posix/src/condwaitsupp.c,
posix/src/mqueueclose.c, posix/src/mqueuecreatesupp.c,
posix/src/mqueuedeletesupp.c, posix/src/mqueuegetattr.c,
posix/src/mqueueunlink.c, posix/src/mutexattrdestroy.c,
posix/src/mutexdefaultattributes.c, posix/src/mutexdestroy.c,
posix/src/mutexgetprioceiling.c, posix/src/mutexinit.c,
posix/src/mutexunlock.c, posix/src/semaphorecreatesupp.c,
posix/src/semaphoredeletesupp.c, posix/src/semaphorewaitsupp.c,
posix/src/semgetvalue.c, posix/src/sempost.c, posix/src/semunlink.c,
posix/src/types.c, score/cpu/powerpc/rtems/old-exceptions/cpu.h:
Remove all pretense of POSIX MP support. The support in place was
only a shell. This should make maintenance easier.
* posix/include/rtems/posix/condmp.h,
posix/include/rtems/posix/mqueuemp.h,
posix/include/rtems/posix/mutexmp.h,
posix/include/rtems/posix/pthreadmp.h,
posix/include/rtems/posix/semaphoremp.h, posix/src/condmp.c,
posix/src/mutexmp.c, posix/src/semaphoremp.c: Removed.
* rtems/score/cpu.h: Do not inline _Thread_Enable_dispatch for Thumb to
save space.
* rtems/score/cpu.h: Eliminate the clicks_per_microsecond field in the
SuperH CPU Table and define another mechanism for drivers to obtain
this information.
MIPS CPU Table and define another mechanism for drivers to obtain
this information.
* rtems/score/cpu.h: Eliminate the interrupt_table_segment and
interrupt_table_offset fields in the i386 CPU Table since they are
never read.
* rtems/score/cpu.h: Eliminate the interrupt_vector_table field in the
m68k CPU Table since it is never read.
* cpu.c, score/cpu.h: Fix headers. Remove extra inline definition.
* cpu_asm.S: Note origin of Thumb support.
* thumb_isr.c: Remove extra debug information, Change function
definition.
* rtems/score/powerpc.h: Added a '__ppc_generic' CPU variant.
The goal would be making cpukit and hopefully libcpu work
for all (or at least most) CPUs/BSPs with -D__ppc_generic so
that eventually all tests [#if defined(<cpu_flavor>)] for CPU
flavors can be eliminated.
* rtems/powerpc/registers.h: Added SPR definitions for BookE
DECAR, TCR, TSR.
* cpu.c: Fix headers.
* thumb_isr.c: Fix headers.
* .cvsignore, ChangeLog, Makefile.am, thumb_isr.c: New files.
* cpu.c, cpu_asm.S, score/cpu.h : add support for ARM<->THUMB veneer
thumb new dir to controll CPSR/SPRS in thumb mode
2007-05-09 Ray Xu <rayx.cn@gmail.com>
* cpu.c: move do_data_abort() to libbsp/arm/shared/abort/
implement a compact do_data_abort() in simple_abort.c
* score/cpu/sparc/cpu.c, score/cpu/sparc/rtems/score/cpu.h,
score/include/rtems/score/context.h, score/src/threadhandler.c: Fix
stack so gdb backtrace does not print corrupted frame message after
_Thread_Handler. Daniel Hellstrom <daniel@gaisler.com> provided the
SPARC implementation and I made it more general.
* cpu_asm.S: Fix two problems:
- CC bit has been clobbered and was not correctly restored
- bfin hardware does not allow to read instructions from the L1
* rtems/bfin/bf533.h: Add more definitions.
* rtems/score/m68k.h: Add stubs for mcf5307, mcf5407, mcfv4e.
* rtems/score/cpu.h: Use uintptr_t instead of uint32_t.
* score/cpu/mips/rtems/score/cpu.h: Use uintptr_t instead of
uint32_t.
* cpu_asm.S, rtems/score/cpu.h, rtems/score/m68k.h:
Replace M68K_COLDFIRE_ARCH with __mcoldfire__.
many different versions of new exception handling code to shared sources.
* cpu.c: Comment out may_alias so this compiles without a compiler
error.
* cpu.c: Merge patch from Till Straumann which would work except gcc
core dumps with an ICE when may_alias is used in this code. I filed a
GCC PR and reduced optimization to -O0 and it does run again.
* rtems/score/cpu.h: Modifiy inline assembly language
constraints to use a data register as the CTL/STI
instructions requires. This is not only more correct,
it avoids GCC PR31787.
* rtems/score/cpu.h: Fix incorrect interrupt mask.
* score/cpu/arm/cpu.c, score/cpu/avr/cpu.c, score/cpu/bfin/cpu.c,
score/cpu/c4x/cpu.c, score/cpu/h8300/cpu.c, score/cpu/i386/cpu.c,
score/cpu/m68k/cpu.c, score/cpu/mips/cpu.c, score/cpu/nios2/cpu.c,
score/cpu/no_cpu/cpu.c, score/cpu/sh/cpu.c, score/cpu/sparc/cpu.c,
cpukit/sapi/src/exinit.c: Move copying of CPU Table to shared
executive initialization.
PR 1237/rtems
* cpu.c, cpu_asm.S, rtems/score/cpu.h: Add logic to prevent stack creep
when interrupts occur at a sufficient rate that the interrupted
thread never gets to clean its stack. This patch ensures that an
interrupted thread will not nest ISR dispatches on its stack.
* rtems/score/cpu.h: Remove CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* rtems/bfin/bf533.h: Fix warnings about constants being too large.
Use Context_Control_fp* instead of void* for fp_contexts.
Eliminate evil casts.
* cpu.c:
