Update #3585.
Update #3585.
Update #3599.
Update #2452.
This function was only used on some m68k variants. On these m68k
variants there is no need to use a global symbol. Use a local label
instead.
Remove _ISR_Dispatch() from the architecture-independent layer.
Rename
* _Configuration_Interrupt_stack_area_begin in _ISR_Stack_area_begin,
* _Configuration_Interrupt_stack_area_end in _ISR_Stack_area_end, and
* _Configuration_Interrupt_stack_size in _ISR_Stack_size.
Move definitions to <rtems/score/isr.h>. The new names are considerable
shorter and in the right namespace.
Update #3459.
Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
This allows to build librtemscpu.a in one rush in the future.
Update #3530.
Update #3533.
The mpc860 is a RTEMS-specific multilib define, see GCC
"gcc/config/rs6000/rtems.h".
If the floating point trap occurred in a delay slot it is not certain
that npc will be equal to pc + 4.
The APIC timer is calibrated by running the i8254 PIT for a fraction of a
second (determined by PIT_CALIBRATE_DIVIDER) and counting how many times the
APIC counter has ticked. The calibration can be run multiple times (determined
by APIC_TIMER_NUM_CALIBRATIONS) and averaged out.
Updates #2898.
Updates #2898.
Updates #2898.
Updates #2898.
Use the CPU_SIZEOF_POINTER alignment instead. The internal alignment
requirement is defined by the use of Chain_Node (consisting of two
pointers) to manage the free chain of partitions.
It seems that previously the condition
CPU_PARTITION_ALIGNMENT >= sizeof(Chain_Node)
was true on all CPU ports. Now, we need an additional check.
Update #3482.
Update #3433.
Update #3433.
The CLINT and PLIC need some per-processor state.
Update #3433.
Update #3433.
Remove _CPU_ISR_install_raw_handler() and _CPU_ISR_install_vector()
functions. Applications can install an exception handler via the fatal
error handler to handle synchronous exceptions.
Handle interrupt exceptions via _RISCV_Interrupt_dispatch() which must
be provided by the BSP.
Update #3433.
Use the CPU_Interrupt_frame for the volatile context. Add non-volatile
registers and extra state on top of it.
Update #3433.
Update #3433.
Apparently the .word assembler directive is not the right thing on this
target.
On some architectures/simulators it is difficult to provoke an
exception with misaligned or illegal data loads. Use an illegal
instruction instead.
Update #3433.
This helps to reduce the use of architecture-specific defines throughout
the code base.
The context validation support functions _CPU_Context_validate() and
_CPU_Context_volatile_clobber() are used only by one test program
(spcontext01). Move the function declarations to the CPU port
implementation header file.
This addition allows us to successfully run the sample hello.exe test.
Updates #2898.
Current state:
- Basic context initialization and switching code.
- Stubbed console (empty functions).
- Mostly functional linker script (may need tweaks if we ever want to move
away from the large code model (see: CPU_CFLAGS).
- Fully functional boot, by using FreeBSD's bootloader to load RTEMS's ELF for
UEFI-awareness.
In short, the current state with this commit lets us boot, go through the system
initialization functions, and then call user application's Init task too.
Updates #2898.
An address must be loaded to a register according to the code model.
Add LADDR define for use in assembler code.
Update #3433.
Update #3433.
See also RISC-V User-Level ISA V2.3, comment in section 8.2
"Load-Reserved/Store-Conditional Instructions".
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
Update #3433.
