* | 2004-09-29 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2004-09-29 | 2 | -4/+5 | |
| | | | | * rtems/score/cpu.h: i960 obsoleted and all references removed. | |||||
* | Remove stray white spaces. | Ralf Corsepius | 2004-04-15 | 1 | -1/+0 | |
* | 2004-04-13 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-13 | 4 | -0/+83 | |
| | | | | | * asm.h: New (stub file. For consistency with other ports, only). * Makefile.am: Add asm.h. | |||||
* | 2004-04-12 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-12 | 2 | -5/+4 | |
| | | | | * rtems/score/cpu.h: Remove defining _POSIX_C_SOURCE for solaris. | |||||
* | 2004-04-09 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-09 | 2 | -2/+6 | |
| | | | | * Makefile.am: Remove LIBC_DEFINES (Unsupported). | |||||
* | Remove (Unused). | Ralf Corsepius | 2004-04-06 | 1 | -2/+0 | |
* | Cleanup | Ralf Corsepius | 2004-04-06 | 1 | -12/+0 | |
* | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-04-06 | 4 | -73/+11 | |
| | | | | | | | | * rtems/score/cpu.h: Remove unixsize.h. * configure.ac: Remove (Merged into$(top_srcdir)/configure.ac). * Makefile.am: Remove unixsize.h. Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | |||||
* | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-30 | 3 | -50/+54 | |
| | | | | * cpu.c, rtems/score/cpu.h: Convert to using c99 fixed size types. | |||||
* | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2004-03-29 | 2 | -1/+5 | |
| | | | | * configure.ac: RTEMS_TOP([../../../..]). | |||||
* | Remove refs to Makefile*. | Ralf Corsepius | 2004-03-09 | 1 | -2/+0 | |
* | Unused. | Ralf Corsepius | 2004-03-08 | 1 | -2/+0 | |
* | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-21 | 2 | -1/+5 | |
| | | | | * configure.ac: Move RTEMS_TOP one subdir down. | |||||
* | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-19 | 2 | -1/+7 | |
| | | | | * Makefile.am: Add PREINSTALL_DIRS. | |||||
* | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-14 | 2 | -0/+8 | |
| | | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | |||||
* | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-12 | 2 | -1/+5 | |
| | | | | * configure.ac: Requires automake >= 1.8.1. | |||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -1/+5 | |
| | | | | * Makefile.am: Include compile.am, again. | |||||
* | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2004-01-11 | 2 | -11/+14 | |
| | | | | * Makefile.am: Convert to using automake compilation rules. | |||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+5 | |
| | | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | |||||
* | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-12 | 2 | -2/+6 | |
| | | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -10/+11 | |
| | | | | * Makefile.am:Restore further parts having been lost. | |||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 1 | -2/+49 | |
| | | | | * Makefile.am: Restore file having been broken in last commit. | |||||
* | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-12-01 | 2 | -51/+6 | |
| | | | | * Makefile.am: Remove TMPINSTALL_FILES. | |||||
* | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-30 | 2 | -10/+15 | |
| | | | | * Makefile.am: Add $(dirstamp) to preinstallation rules. | |||||
* | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-11-23 | 2 | -19/+28 | |
| | | | | * Makefile.am: Don't use gmake rules for preinstallation. | |||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -2/+4 | |
| | | | | * configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
* | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-10-21 | 2 | -1/+4 | |
| | | | | * configure.ac: Remove RTEMS_CHECK_CPU. | |||||
* | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-26 | 2 | -9/+7 | |
| | | | | | * rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | |||||
* | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-09-04 | 5 | -4/+9 | |
| | | | | | * cpu.c, rtems/score/cpu.h, rtems/score/types.h, rtems/score/unix.h: URL for license changed. | |||||
* | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2003-08-11 | 2 | -1/+5 | |
| | | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-04-17 | 2 | -1/+7 | |
* | Merger from rtems-4-6-branch. | Ralf Corsepius | 2003-03-11 | 2 | -1/+4 | |
* | 2003-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2003-01-03 | 2 | -4/+8 | |
| | | | | | * rtems/score/cpu.h: Per PR315, eliminate warning for structure alignment requests that are too large. | |||||
* | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-12-11 | 3 | -7/+10 | |
| | | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | |||||
* | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-19 | 2 | -1/+5 | |
| | | | | * configure.ac: Fix package name. | |||||
* | 2002-11-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-11-12 | 3 | -2/+23 | |
| | | | | | | * configure.ac: Generate unixsize.h on the fly, filter out autoconf-2.53 PACKAGE crap. * rtems/score/.cvsignore: unixsize* | |||||
* | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-25 | 2 | -1/+5 | |
| | | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
* | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-10-21 | 2 | -3/+9 | |
| | | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
* | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-26 | 2 | -7/+9 | |
| | | | | * Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | |||||
* | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-22 | 2 | -1/+5 | |
| | | | | * Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
* | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-05 | 2 | -1/+5 | |
| | | | | * configure.ac: RTEMS_TOP(../../../..). | |||||
* | 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-07-01 | 2 | -2/+4 | |
| | | | | * configure.ac: Remove RTEMS_PROJECT_ROOT. | |||||
* | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-27 | 2 | -1/+7 | |
| | | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB. | |||||
* | 2002-06-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-26 | 2 | -1/+5 | |
| | | | | * configure.ac: Remove references to RTEMS_BSP. | |||||
* | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2002-06-17 | 2 | -5/+10 | |
| | | | | | * Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal. | |||||
* | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-04-03 | 3 | -2/+9 | |
| | | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/unixtypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change. | |||||
* | 2001-03-28 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-03-28 | 2 | -0/+7 | |
| | | | | * cpu.c: Define fix_syscall_errno() to nothing so MP links. | |||||
* | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-03-28 | 3 | -3/+9 | |
| | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
* | 2002-02-13 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2002-02-13 | 2 | -8/+4 | |
| | | | | * configure.ac: Fix the test to determine cpu context size. | |||||
* | 2001-02-05 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-05 | 2 | -0/+5 | |
| | | | | * .cvsignore: Added stamp-h.in. |
