* rtems/score/cpu.h: Remove #undef __STRICT_ANSI__.
* cpu.c, rtems/score/cpu.h: Bug report from Peter Mueller
<peter.o.mueller@gmx.de> because of not correcting for the ISR
vector table now being allocated from the workspace.
* Makefile.am: Use += to set up AM_CPPFLAGS.
* rtems/score/Makefile.am: Use PROJECT_TOPdir in path to gensize.
_Interrupt_Manager_initialization.
converted to automake.
bugs.
rm -rf c/src/exec/score/cpu/i960/wrap
rm -rf c/src/exec/score/cpu/m68k/wrap
rm -rf c/src/exec/score/cpu/sh/wrap
rm -rf c/src/exec/score/cpu/sparc/wrap
rm -rf c/src/exec/score/cpu/unix/wrap
patch -p1 < rtems-rc-19991123-rc-1.diff
./bootstrap
Known bugs:
* "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does
not handle recursion to subdirectories correctly (recurses too often).
However, this issue is hardly visible and should be tolerable for the
moment.
port only uses System V IPC for shared memory and semaphores to
communicate between nodes in a multiprocessor configuration. If you
disable multiprocessing, then this code should be unused. Thus systems
like Cygwin which are POSIX but do not support System V IPC should
not work.
sigemptyset(&old_mask) needed to be added on glibc2 systems. Ian
Lance Taylor pointed out that sigemptyset() is portable so Joel removed
all conditionals around calls to sigemptyset().
After upgrading my linux box to the brand new SuSE 6.2 release, which is
glibc-2.1 based, I came across a bug in RTEMS - IIRC, I even warned you
about it about 1/2 a year ago, but nothing has been done since then :-.
The *.m4 macros to check for SYSV/IPC are broken for linux/glibc2.1,
because they assume that linux always defines union semun, which isn't
true anymore for glibc2.1 (the manpage for semctl states _X_OPEN
specifies it this way). Therefore I have tried to implement a more
general approach for handling SYSV for unix/posix which checks for
presence of struct semun, instead of trying to evaluate OS specific
preprocessor symbols.
This approach is a bit adventureous, because I only tested it with
linux/glibc2.1 and linux/libc5, but not under other Unix variants RTEMS
supports. I am quite confident it will work on other hosts, too, but who
knows :-.
[FYI: I think this might also is the cause of some problems with RedHat
6.X / Mandrake linux recently reported on the rtems list -- rtems-4.0.0
can not be build for posix on any glibc2.1 based host]
Furthermore the patch below contains a couple of minor fixes and
configuration cleanups, which IMO should be applied before releasing a
new snapshot.
To apply this patch:
patch -p1 < rtems-rc-19990709-8.diff
> out most bugs.
a29k/asm.h
a29k/cpu_asm.h
i386/asm.h
i960/asm.h
m68k/asm.h
m68k/m68302.h
m68k/m68360.h
m68k/qsm.h
m68k/sim.h
mips64orion/asm.h
mips64orion/cpu_asm.h
mips64orion/mips64orion.h
no_cpu/asm.h
no_cpu/cpu_asm.h
powerpc/asm.h
powerpc/mpc860.h
sh/asm.h
sparc/asm.h
sparc/erc32.h
I just happened across the sync_io support in
c/src/exec/score/cpu/unix/cpu.c
(is this documented anywhere?). That looked more useful than the
signal driven I/O I was using before, so I tried it. I ran across a
few bugs in the way it uses select.
Select changes its fd_set arguments, so you can't use global variables
for them. You have to copy them into local variables first.
If select returns -1 with errno set to EINTR, then it has not changed
any of the fd_sets. You can't start looking at them.
When clearing a descriptor, the code has the usual select off by one
error when setting sync_io_nfds.
I don't see how this code could ever have worked correctly.
I have appended a patch for the problems I found.
gcc-target-default.cfg
It appears that the new glibc does not clear all the bits of the signal
set with a sigprocmask.
the CPU family name constants.
suggestion.
in the unix port idle thread task. This should keep the entire application
from blocking when any component does a blocking application. Also added
TOD_MICROSECONDS_TO_TICKS.
semctl was being invoked.
be resolved.
added CPU_STRUCTURE_ALIGNMENT to default context structures
Broke the setjmp/longjmp pair in the context switch into a separate routine
so no code depended on local variables surviving the jump.
updates from Tony Bennett. Most were to insure all variables were properly
initialized and to correct the stray signal number reporting.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
