2004-11-02 | 2004-10-02 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 4 | -6/+21 | |
* rtems/score/cpu.h: Add doxygen preamble. * rtems/score/sparc.h: Add doxygen preamble. * rtems/score/types.h: Add doxygen preamble. | |||||
2004-04-15 | Remove stray white spaces. | Ralf Corsepius | 2 | -4/+0 | |
2004-04-08 | Add missing PR604 reference. | Joel Sherrill | 1 | -0/+1 | |
2004-04-06 | Cosmetics. | Ralf Corsepius | 1 | -1/+0 | |
2004-04-06 | Cleanup | Ralf Corsepius | 1 | -12/+0 | |
2004-04-06 | 2004-04-06 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 3 | -30/+8 | |
* configure.ac: Remove (Merged into$(top_srcdir)/configure.ac). * Makefile.am: Don't include multilib.am. Reflect merging configure.ac into $(top_srcdir)/configure.ac. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -8/+13 | |
* Makefile.am: Install asm.h to $(includedir)/rtems. | |||||
2004-04-01 | 2004-04-01 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* cpu_asm.S: Include <rtems/asm.h> instead of <asm.h>. | |||||
2004-03-30 | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 4 | -115/+120 | |
* cpu.c, rtems/score/cpu.h, rtems/score/sparc.h: Convert to using c99 fixed size types. | |||||
2004-03-29 | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: RTEMS_TOP([../../../..]). | |||||
2004-03-08 | Unused. | Ralf Corsepius | 2 | -4/+0 | |
2004-02-26 | 2004-02-26 Andreas Karlsson <andreas.karlsson@space.se> | Joel Sherrill | 2 | -0/+16 | |
* cpu_asm.S: Close window while restoring interrupted task state which resulted in CWP corruption. | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Move RTEMS_TOP one subdir down. | |||||
2004-01-19 | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+8 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+9 | |
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | |||||
2004-01-12 | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Requires automake >= 1.8.1. | |||||
2004-01-11 | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* Makefile.am: Include compile.am, again. | |||||
2004-01-11 | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -14/+14 | |
* Makefile.am: Convert to using automake compilation rules. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -4/+6 | |
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -10/+16 | |
* Makefile.am:Restore further parts having been lost. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -2/+52 | |
* Makefile.am: Restore file having been broken in last commit. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -59/+6 | |
* Makefile.am: Remove TMPINSTALL_FILES. | |||||
2003-11-30 | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -10/+20 | |
* Makefile.am: Add $(dirstamp) to preinstallation rules. | |||||
2003-11-23 | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -18/+27 | |
* Makefile.am: Don't use gmake rules for preinstallation. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+4 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+4 | |
* configure.ac: Remove RTEMS_CHECK_CPU. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 6 | -5/+10 | |
* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/sparc.h, rtems/score/types.h: URL for license changed. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 2 | -1/+4 | |
2002-12-11 | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 3 | -7/+10 | |
* configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Fix package name. | |||||
2002-10-25 | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -3/+9 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-08-08 | 2002-08-08 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+5 | |
* cpu.c: Move pointer into #ifdef to avoid compiler warning. | |||||
2002-07-26 | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -7/+9 | |
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | |||||
2002-07-22 | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+6 | |
* Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
2002-07-05 | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+5 | |
* configure.ac: RTEMS_TOP(../../../..). | |||||
2002-07-03 | 2002-07-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -6/+6 | |
* rtems.S: Remove. * Makefile.am: Reflect changes above. | |||||
2002-07-01 | 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -2/+4 | |
* configure.ac: Remove RTEMS_PROJECT_ROOT. | |||||
2002-06-27 | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -0/+5 | |
* configure.ac: Add RTEMS_PROG_CCAS | |||||
2002-06-27 | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -1/+7 | |
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB. | |||||
2002-06-17 | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 2 | -5/+10 | |
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal. | |||||
2002-04-03 | 2002-04-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -24/+6 | |
* cpu.c: Remove call to sparc_init_tbr/NO_TABLE_MOVE. * rtems/score/cpu.h: Remove NO_TABLE_MOVE conditional code. | |||||
2002-04-03 | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 3 | -2/+9 | |
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/sparctypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change. | |||||
2002-03-29 | 2002-03-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -32/+10 | |
* cpu.c: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.c). * cpu.h: Replace NO_TABLE_MOVE-support by external function (code moved to libcpu/sparc/tbr/tbr.h). * sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c). | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 3 | -3/+9 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2002-01-31 | 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -26/+27 | |
* Makefile.am: Reflect 2002-01-23 changes. | |||||
2002-01-30 | 2001-01-30 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2 | -3/+20 | |
* Makefile.am: Corrected so .h files from rtems/score/ are installed. | |||||
2002-01-24 | 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2 | -3/+7 | |
* rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. |
