The sparc64 port had some incorrect copyright notices affixed to
source code files.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
not updated.
Rename Priority_bit_map_Control in Priority_bit_map_Word.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
Add proper license and copyright.
Add CPU port specific per-CPU control.
architectures. SMP atomic port will be later.
comments in the RTEMS source.
https://google-melange.appspot.com/gci/task/view/google/gci2012/7977211
Add CPU port type CPU_Exception_frame and function
_CPU_Exception_frame_print().
The CPU ports of avr, bfin, h8300, lm32, m32c, m32r, m68k, nios2, sh,
sparc64, and v850 use an empty default implementation of
Add rtems_exception_frame and rtems_exception_frame_print().
Add RTEMS_FATAL_SOURCE_EXCEPTION for CPU exceptions. Use rtems_fatal()
with source RTEMS_FATAL_SOURCE_EXCEPTION in CPU ports of i386, powerpc,
and sparc for unexpected exceptions.
Add third parameter to RTEMS_BSP_CLEANUP_OPTIONS() which controls the
BSP_PRINT_EXCEPTION_CONTEXT define used in the default
bsp_fatal_extension().
Add test sptests/spfatal26.
Add and use new CPU port define CPU_SIZEOF_POINTER. It must be an
integer literal that can be used by the assembler. This value will be
used to calculate offsets of structure members. These offsets will be
used in assembler code.
The size of a pointer is part of the application binary interface (ABI)
and thus independent of the actual programming language. The compiler
will provide defines to determine the current ABI. We use these defines
to select the appropriate CPU_SIZEOF_POINTER value.
Static assertions in the new file "cpukit/score/src/percpuasm.c" will
ensure that the value of CPU_SIZEOF_POINTER is consistent with the
current compiler settings. Also the offset values used by assembler
code are verfied.
for details.
Add the trap vector to the interrupt frame. Also rename the assembly
macro that accesses the field to be consistent with similar macros.
PR 1918/cpukit
* cpu.c: Initialize context with cleared g4 register.
PR 1914/cpukit
* rtems/score/cpu.h: Select timestamp implementation.
* cpu.c: Remove /*PAGE markers which were interpreted by a long dead
print script.
* Makefile.am: Reformat.
* rtems/score/cpu.h, rtems/score/sparc64.h:
* rtems/score/sparc64.h: Fix typo.
* rtems/score/cpu.h: Add RTEMS_COMPILER_NO_RETURN_ATTRIBUTE to
_CPU_Context_restore() because it does not return. Telling GCC this
avoids generation of dead code.
PR 1681/cpukit
* rtems/score/cpu.h: With the percpu patch, ASM uses
INTERRUPT_STACK_HIGH instead of _CPU_Interrupt_stack_high. The
sparc64 was still using the old variable, which was declared in its
cpu.h file. This patch comments out the declaration and switch to
using INTERRUPT_STACK_HIGH.
PR 1635/cpukit
* rtems/score/types.h: Refactoring of priority handling, to isolate the
bitmap implementation of priorities in the supercore so that priority
management is a little more modular. This change is in anticipation
of scheduler implementations that can select how they manage tracking
priority levels / finding the highest priority ready task. Note that
most of the changes here are simple renaming, to clarify the use of
the bitmap-based priority management.
* rtems/score/cpu.h: Include <rtems/score/types.h> first.
* rtems/score/types.h: Use <rtems/score/basedefs.h> header file.
PR 1561/cpukit
* .cvsignore, ChangeLog, Makefile.am, Makefile.in, README, context.S,
cpu.c, preinstall.am, rtems/asm.h, rtems/score/cpu.h,
rtems/score/sparc64.h, rtems/score/types.h: New files.
