* cpu.c, cpu_asm.S, rtems/score/cpu.h, rtems/score/sparc.h,
rtems/score/types.h: URL for license changed.
* cpu.c: Move pointer into #ifdef to avoid compiler warning.
* cpu.c: Remove call to sparc_init_tbr/NO_TABLE_MOVE.
* rtems/score/cpu.h: Remove NO_TABLE_MOVE conditional code.
* cpu.c: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.c).
* cpu.h: Replace NO_TABLE_MOVE-support by external function
(code moved to libcpu/sparc/tbr/tbr.h).
* sparc.h: Add sparc_init_tbr (implemented in libcpu/sparc/tbr/tbr.c).
* cpu.c: Added include of <rtems/rtems/cache.h> to eliminate warning.
* cpu.c, rtems/cpu/sparc.h: Make floating point optional based
on gcc arguments. Do not initialize FP context if there is
no FPU. Flush instruction cache after installing RTEMS trap handler.
are now in libcpu. This primarily required moving erc32 specific
information from score/cpu files to libcpu/sparc and the erc32 BSP.
This is current as of sis 2.6.
part of the Thread Handler. This required the name of the optional
CPU dependent IDLE thread implementation to change.
like signal dispatching.
