Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets
rid of all subtree Makefile.am and the sudirs hack.
Remove the CPU_PROVIDES_IDLE_THREAD_BODY option to avoid unnecessary
conditional compilation.
Close #3539.
This allows to build librtemscpu.a in one rush in the future.
This file is BSP-independent.
Update #3285.
Update #3285.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3254.
Update #3260.
The SPARC ABI is a bit special with respect to the floating point context.
The complete floating point context is volatile. Thus, from an ABI point
of view nothing needs to be saved and restored during a context switch.
Instead the floating point context must be saved and restored during
interrupt processing. Historically, the deferred floating point switch was
used for SPARC and the complete floating point context is saved and
restored during a context switch to the new floating point unit owner.
This is a bit dangerous since post-switch actions (e.g. signal handlers)
and context switch extensions may silently corrupt the floating point
context.
The floating point unit is disabled for interrupt handlers. Thus, in case
an interrupt handler uses the floating point unit then this will result in a
trap (INTERNAL_ERROR_ILLEGAL_USE_OF_FLOATING_POINT_UNIT).
In uniprocessor configurations, a lazy floating point context switch is
used. In case an active floating point thread is interrupted (PSR[EF] == 1)
and a thread dispatch is carried out, then this thread is registered as the
floating point owner. When a floating point owner is present during a
context switch, the floating point unit is disabled for the heir thread
(PSR[EF] == 0). The floating point disabled trap checks that the use of the
floating point unit is allowed and saves/restores the floating point context
on demand.
Update #3077.
The aim of this file is to encapsulate CPU port implementation details.
This helps to hide implementation details from <rtems.h> which
indirectly includes <rtems/score/cpu.h>.
Rework CPU counter support to enable use of the GR740 up-counter via
%asr22 and %asr23.
Close #2695.
Implement _CPU_Context_validate() and _CPU_Context_volatile_clobber().
Update #2270.
The SPARC processors supported by RTEMS have no built-in CPU counter
support. We have to use some hardware counter module for this purpose.
The BSP must provide a 32-bit register which contains the current CPU
counter value and a function for the difference calculation. It can use
for example the GPTIMER instance used for the clock driver.
Use a ticket lock implementation based on atomic operations. Delete CPU
port specific SMP lock implementations.
Use SWAP instruction with one lock for the system in the SMP case.
Move the SMP lock implementation to the CPU port. An optimal SMP lock
implementation is highly architecture dependent. For example the memory
models may be fundamentally different.
The new SMP lock API has a flaw. It does not provide the ability to use
a local context for acquire and release pairs. Such a context is
necessary to implement for example the Mellor-Crummey and Scott (MCS)
locks. The SMP lock is currently used in _Thread_Disable_dispatch() and
_Thread_Enable_dispatch() and makes them to a giant lock acquire and
release. Since these functions do not pass state information via a
local context there is currently no use case for such a feature.
architectures. SMP atomic port will be later.
for details.
* Makefile.am: Reformat.
* Makefile.am: Split out preinstallation rules.
* preinstall.am: New (Split out from Makefile.am).
PR 754/rtems
* rtems/asm.h: New (relocated from .).
* asm.h: Remove (moved to rtems/asm.h).
* Makefile.am: Eliminate CFLAGS_OPTIMIZE_V.
* Makefile.am: Remove build-variant support.
* configure.ac: Remove (Merged into$(top_srcdir)/configure.ac).
* Makefile.am: Don't include multilib.am.
Reflect merging configure.ac into $(top_srcdir)/configure.ac.
* Makefile.am: Install asm.h to $(includedir)/rtems.
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES.
Add PREINSTALL_FILES to CLEANFILES.
* Makefile.am: Include compile.am, again.
* Makefile.am: Convert to using automake compilation rules.
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* Makefile.am:Restore further parts having been lost.
* Makefile.am: Restore file having been broken in last commit.
* Makefile.am: Remove TMPINSTALL_FILES.
* Makefile.am: Add $(dirstamp) to preinstallation rules.
* Makefile.am: Don't use gmake rules for preinstallation.
* configure.ac: Require autoconf-2.57 + automake-1.7.2.
* Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* Makefile.am: Use .$(OBJEXT) instead of .o.
* rtems.S: Remove.
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am.
Use ../../../aclocal.
* rtems/score/sparctypes.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* Makefile.am: Reflect 2002-01-23 changes.
