path: root/cpukit/score/cpu/sh (follow)
* Patch rtems-rc-20000711-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-112-2/+2
| | | | | | | | | that decouples exec/ for the sh, m68k and i960 from targopts.h. NOTE: The change to system.h is a hack to enable cpuopts.h for some targets, but keep using targopts.h for others - I know it does *not* work for sparc, mips, i386 and ppc. This will have to be addressed as work continues on multilibing.
* Interrupt stack is allocated in _ISR_Handler_initialization notJoel Sherrill2000-07-031-1/+1
| | | | _Interrupt_Manager_initialization.
* Patch rtems-rc-20000614-sh.tar.gz from Ralf CorsepiusJoel Sherrill2000-06-142-11/+12
| | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> that migrates the SH port to multilib'ing. This patch involved moving a number of files in the CVS repository, adding new files, and deleting files from their previous location. Ralf gave good instructions (not repeated here) and here are his notes: Note 1: In this version, I did not change the installation points of the headers which are moved inside of the source-tree. This is a temporary hack for not breaking compatibility with 4.5 based BSPs, but will probably not last once having real multilibs (We would have include file conflicts when several BSPs/CPU_MODELS share a common installation prefix). Note 2: I hope not to have broken too much, but I would not be astonished if something goes wrong. Note 3: There are more patches to come :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-122-4/+15
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+17
| | | | adds .cvsignore.
* Patches rtems-rc-20000118-3.diff and rtems-rc-20000118-4.diff fromJoel Sherrill2000-01-311-18/+12
| | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that contain: * Modifications, (minor) corrections, cleanups to most existing Makefile.ams * Adds automake support to all remaining BSPs which have not yet been converted to automake. * Makefile.am for all remaining wrapup/Makefile.ams
* Patch rtems-rc-19991123-rc-1.diff from Ralf CorsepiusJoel Sherrill1999-12-011-0/+51
| | | | | | | | | | | | | | | | | | | | | | | <corsepiu@faw.uni-ulm.de> which implements automake support for some score/cpu/<RTEMS_CPU> subdirectories and fixes a few minor configuration bugs. To apply: rm -rf c/src/exec/score/cpu/i960/wrap rm -rf c/src/exec/score/cpu/m68k/wrap rm -rf c/src/exec/score/cpu/sh/wrap rm -rf c/src/exec/score/cpu/sparc/wrap rm -rf c/src/exec/score/cpu/unix/wrap patch -p1 < rtems-rc-19991123-rc-1.diff ./bootstrap Known bugs: * "make debug|profile" in c/src/src/score/cpu/<RTEMS_CPU/Makefile does not handle recursion to subdirectories correctly (recurses too often). However, this issue is hardly visible and should be tolerable for the moment.
* Small patch (rtems-rc-19991117-5.diff) from Ralf CorsepiusJoel Sherrill1999-11-221-1/+1
| | | | | <corsepiu@faw.uni-ulm.de> to correct the constraints on the inline assembly language macro for sh_disable_interrupt.
* Minor cleanup to reduce the code space.Joel Sherrill1999-11-181-14/+9
* Patch from "John M. Mills" <jmills@tga.com> with subsequent cleanup fromJoel Sherrill1999-11-183-4/+16
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Ralf Corsepius <corsepiu@faw.uni-ulm.de> that adds initial Hitachi SH-2 support to RTEMS. Ralf's comments are: Changes: ------ 1. SH-Port: * Many files renamed. * CONSOLE_DEVNAME and MHZ defines removed from libcpu. * console.c moved to libbsp/sh/shared, build in libbsp/sh/<BSP>/console applying VPATH. * CONSOLE_DEVNAME made BSP-specific, replacement is defined in bsp.h * MHZ define replaced with HZ (extendent resolution) in custom/*.cfg * -DHZ=HZ used in bspstart.c, only * Makefile variable HZ used in bsp-dependent directories only. 2. SH1-Port * clock-driver rewritten to provide better resolution for odd CPU frequencies. This driver is only partially tested on hardware, ie. sightly experimental, but I don't expect severe problems with it. * Polling SCI-driver added. This driver is experimental and completly untested yet. Therefore it is not yet used for the console (/dev/console is still pointing to /dev/null, cf. gensh1/bsp.h). * minor changes to the timer driver * SH1 specific delay()/CPU_delay() now is implemented as a function 3. SH2-Port * Merged * IMO, the code is still in its infancy. Therefore I have interspersed comments (FIXME) it for items which I think John should look after. * sci and console drivers partially rewritten and extended (John, I hope you don't mind). * Copyright notices are not yet adapted
* This is another pass at making sure that nothing outside the BSPJoel Sherrill1999-11-051-0/+11
| | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>.
* Patch rtems-rc-19991011-3.diff from Ralf Corsepius.Joel Sherrill1999-10-281-25/+0
* Patch from Charles-Antoine Gauthier <charles.gauthier@iit.nrc.ca>Joel Sherrill1999-07-291-1/+1
| | | | | to correct a typo CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES was actually typed in as CPU_CPU_HAS_OWN_HOST_TO_NETWORK_ROUTINES.
* Moved asm.h back up in tree.Joel Sherrill1999-02-192-0/+274
* Moved to proper rtems/scoreJoel Sherrill1999-02-192-274/+0
* Part of the automake VI patch from Ralf Corsepius <corsepiu@faw.uni-ulm.de>:Joel Sherrill1999-02-184-0/+1176
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | > 4) rtems-rc-19990202-0.diff /reorg-score-cpu.sh > > reorg-score-cpu.sh reorganizes the cpu/<cpu>/* subdirectories in a > similar manner than previous reorg scripts did. rtems-rc-19990202-0.diff > contains the diffs after reorg-score-cpu.sh has been run on a > rtems-19981215 snapshot + my patches up to rtems-rc-19990131-2.diff. > > This patch is rather nasty and may break something. However, I've tested > it for about 10 different target/bsp pairs and believe to have shaken > out most bugs. I wonder about the following .h files that were not moved: a29k/asm.h a29k/cpu_asm.h i386/asm.h i960/asm.h m68k/asm.h m68k/m68302.h m68k/m68360.h m68k/qsm.h m68k/sim.h mips64orion/asm.h mips64orion/cpu_asm.h mips64orion/mips64orion.h no_cpu/asm.h no_cpu/cpu_asm.h powerpc/asm.h powerpc/mpc860.h sh/asm.h sparc/asm.h sparc/erc32.h
* SH port submitted from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1998-03-203-0/+506
