path: root/cpukit/score/cpu/sh/include/rtems (unfollow)
2018-06-27score: Add CPU_INTERRUPT_STACK_ALIGNMENTSebastian Huber1-0/+2
Add CPU port define for the interrupt stack alignment. The alignment should take the stack ABI and the cache line size into account. Update #3459.
2018-06-15Add _CPU_Counter_frequency()Sebastian Huber1-0/+2
Add rtems_counter_frequency() API function. Use it to initialize the counter value converter via the new system initialization step (RTEMS_SYSINIT_CPU_COUNTER). This decouples the counter implementation and the counter converter. It avoids an unnecessary pull in of the 64-bit integer division from libgcc. Update #3456.
2018-04-16Remove register keyword from public header filesSebastian Huber1-4/+4
The following code void f(void) { register int i; } gives a warning with GCC and -std=c++17 test.cc: In function ‘void f()’: test.cc:3:15: warning: ISO C++1z does not allow ‘register’ storage class specifier [-Wregister] register int i; ^ and clang with -std=c++14 test.cc:3:3: warning: 'register' storage class specifier is deprecated and incompatible with C++1z [-Wdeprecated-register] register int i; ^~~~~~~~~ 1 warning generated. Remove the use of the register keyword at least in the public header files for C++ compatibility. Close #3397.
2018-03-12sh/include/rtems/score/types.h: Eliminate this fileJoel Sherrill2-57/+8
Updates #3327.
2018-01-25Remove make preinstallChris Johns7-0/+1307
