path: root/cpukit/score/cpu/sh/include/rtems/score/sh.h (follow)
* Remove register keyword from public header filesSebastian Huber2018-04-161-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | The following code void f(void) { register int i; } gives a warning with GCC and -std=c++17 test.cc: In function ‘void f()’: test.cc:3:15: warning: ISO C++1z does not allow ‘register’ storage class specifier [-Wregister] register int i; ^ and clang with -std=c++14 test.cc:3:3: warning: 'register' storage class specifier is deprecated and incompatible with C++1z [-Wdeprecated-register] register int i; ^~~~~~~~~ 1 warning generated. Remove the use of the register keyword at least in the public header files for C++ compatibility. Close #3397.
* Remove make preinstallChris Johns2018-01-251-0/+277
