path: root/cpukit/score/cpu/sh/headers.am (follow)
* build: Include header.am in cpukit/Makefile.amSebastian Huber2018-10-101-12/+6
| | | | | Include all cpukit/*/header.am files in cpukit/Makefile.am. This gets rid of all subtree Makefile.am and the sudirs hack.
* sh/include/rtems/score/types.h: Eliminate this fileJoel Sherrill2018-03-121-1/+0
| | | | Updates #3327.
* Remove make preinstallChris Johns2018-01-251-0/+14
