2004-03-30 | 2004-03-30 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+5 | |
* cpu.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h: Convert to using c99 fixed size types. | |||||
2004-03-29 | 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: RTEMS_TOP([../../../..]). | |||||
2004-01-21 | 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Move RTEMS_TOP one subdir down. | |||||
2004-01-19 | 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Add PREINSTALL_DIRS. | |||||
2004-01-14 | 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES. | |||||
2004-01-12 | 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Requires automake >= 1.8.1. | |||||
2004-01-11 | 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Include compile.am, again. | |||||
* Makefile.am: Convert to using automake compilation rules. | |||||
2003-12-12 | 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES. | |||||
* configure.ac: Require automake >= 1.8, autoconf >= 2.59. | |||||
2003-12-01 | 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Remove TMPINSTALL_FILES. | |||||
2003-11-30 | 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Add $(dirstamp) to preinstallation rules. | |||||
2003-11-23 | 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Don't use gmake rules for preinstallation. | |||||
2003-10-21 | 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_CANONICAL_HOST. | |||||
* configure.ac: Remove RTEMS_CHECK_CPU. | |||||
2003-09-26 | 2003-09-26 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all references. | |||||
2003-09-04 | 2003-09-04 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+5 | |
* asm.h, cpu.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h, rtems/score/types.h: URL for license changed. | |||||
2003-08-11 | 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Use rtems-bugs@rtems.com as bug report email address. | |||||
2003-03-11 | Merger from rtems-4-6-branch. | Ralf Corsepius | 1 | -0/+4 | |
2002-12-11 | 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS. | |||||
2002-11-19 | 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Fix package name. | |||||
2002-10-25 | 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add nostdinc to AM_INIT_AUTOMAKE. | |||||
* rtems/score/sh.h: Fix typo in comment (Starus->Status). | |||||
2002-10-21 | 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+6 | |
* .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache. | |||||
2002-07-26 | 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel. | |||||
2002-07-22 | 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* Makefile.am: Use .$(OBJEXT) instead of .o. | |||||
2002-07-05 | 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: RTEMS_TOP(../../../..). | |||||
2002-07-03 | 2002-07-03 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* rtems.c: Remove. * Makefile.am: Reflect changes above. | |||||
2002-07-01 | 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Remove RTEMS_PROJECT_ROOT. | |||||
2002-06-27 | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+4 | |
* configure.ac: Add RTEMS_PROG_CCAS | |||||
2002-06-27 | 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB. | |||||
2002-06-17 | 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Ralf Corsepius | 1 | -0/+5 | |
* Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal. | |||||
2002-04-08 | 2002-04-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* rtems.c: Adaptation to gcc-3.0.x. | |||||
2002-04-03 | 2001-04-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+7 | |
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/shtypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change. | |||||
2002-03-28 | 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+7 | |
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. | |||||
2002-02-01 | 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Reflect 2002-01-23 changes. | |||||
2002-01-31 | 2002-01-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
2002-01-24 | 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+6 | |
* rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. | |||||
2001-12-19 | 2001-12-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Add multilib support. | |||||
2001-11-28 | 2001-11-28 Joel Sherrill <joel@OARcorp.com>, | Joel Sherrill | 1 | -0/+7 | |
This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. | |||||
2001-10-15 | 2001-10-15 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* cpu.c: Fix #ifdefs, add missing #endif. | |||||
2001-10-12 | 2001-10-12 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+6 | |
* asm.h, cpu.c, rtems.c, rtems/score/cpu.h, rtems/score/sh.h, rtems/score/sh_io.h, rtems/score/shtypes.h: Consistency changes and made sure there were no includes from the libcpu tree. | |||||
2001-10-12 | 2001-10-12 Alexandra Kossovsky <sasha@oktet.ru> | Joel Sherrill | 1 | -0/+6 | |
* cpu.c, rtems/score/cpu.h, rtems/score/sh.h: Modified to support SH4. Reviewed by Ralf Corsepius <corsepiu@faw.uni-ulm.de> who did the original SH port. | |||||
2001-10-11 | 2001-10-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+6 | |
* .cvsignore: Add autom4te.cache for autoconf > 2.52. * configure.in: Remove. * configure.ac: New file, generated from configure.in by autoupdate. | |||||
2001-09-27 | 2001-09-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* rtems/score/Makefile.am: Use 'PREINSTALL_FILES ='. * Makefile.am: Use 'PREINSTALL_FILES ='. | |||||
2001-08-16 | 2001-07-25 Radzislaw Galler <rgaller@et.put.poznan.pl> | Joel Sherrill | 1 | -0/+6 | |
* cpu.c (_CPU_ISR_install_vector): Corrected interrupt range checking which was SH1 specific. It didn't work for SH2 (has more interrupt sources). | |||||
2001-02-05 | 2001-02-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+5 | |
* Makefile.am, rtems/score/Makefile.am: Apply include_*HEADERS instead of H_FILES. | |||||
2001-01-03 | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -0/+4 | |
* rtems/score/cpu.h: Added _CPU_Initialize_vectors(). | |||||
2000-11-09 | 2000-11-09 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Use ... instead of RTEMS_TOPdir in ACLOCAL_AMFLAGS. | |||||
2000-11-02 | 2000-11-02 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1 | -0/+4 | |
* Makefile.am: Switch to ACLOCAL_AMFLAGS = -I $(RTEMS_TOPdir)/aclocal. |
