* | cpukit: RISC-V - make riscv32 code work for riscv64 - v2 | Hesham Almatary | 2017-11-01 | 1 | -0/+45 |
* Use #ifdefs for 32/64 bit code * Use unsigned long which is 32-bit on riscv32 and 64-bit on riscv64 (register size) * Move the code to a new shared riscv folder to be shared between riscv32 and riscv64 * Rename RTEMS_CPU extracted from command line to shared riscv target s/riscv*/riscv Update #3109 |
