path: root/cpukit/score/cpu/powerpc (follow)
* 2004-03-29 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-03-292-1/+5
| | | | * configure.ac: RTEMS_TOP([../../../..]).
* Unused.Ralf Corsepius2004-03-082-4/+0
* 2004-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-212-1/+5
| | | | * configure.ac: Move RTEMS_TOP one subdir down.
* 2004-01-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-192-5/+11
| | | | * Makefile.am: Add PREINSTALL_DIRS.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-142-0/+12
| | | | | * Makefile.am: Re-add dirstamps to PREINSTALL_FILES. Add PREINSTALL_FILES to CLEANFILES.
* 2004-01-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-122-1/+5
| | | | * configure.ac: Requires automake >= 1.8.1.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-1/+5
| | | | * Makefile.am: Include compile.am, again.
* 2004-01-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-112-2/+5
| | | | * Makefile.am: Convert to using automake compilation rules.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-10/+9
| | | | * Makefile.am: Use mkdir_p. Remove dirs from PREINSTALL_FILES.
* 2003-12-12 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-122-2/+6
| | | | * configure.ac: Require automake >= 1.8, autoconf >= 2.59.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-22/+31
| | | | * Makefile.am:Restore further parts having been lost.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-31/+22
| | | | * Makefile.am: Restore file having been broken in last commit.
* 2003-11-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-302-22/+35
| | | | * Makefile.am: Add $(dirstamp) to preinstallation rules.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-11/+5
| | | | * Makefile.am: Remove all LIB-related rules.
* 2003-11-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-11-232-38/+51
| | | | * Makefile.am: Don't use gmake rules for preinstallation.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-212-2/+4
| | | | * configure.ac: Remove RTEMS_CANONICAL_HOST.
* 2003-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-10-212-1/+4
| | | | * configure.ac: Remove RTEMS_CHECK_CPU.
* 2003-09-26 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-263-14/+5
| | | | | * rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h: Obsoleting HP PA-RISC port and removing all references.
* 2003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2003-09-046-5/+11
| | | | | | * rtems/new-exceptions/cpu.h, rtems/old-exceptions/cpu.h, rtems/powerpc/registers.h, rtems/score/ppc.h, rtems/score/types.h: URL for license changed.
* 2003-08-21 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-08-212-7/+14
| | | | | | PR 457/bsps * rtems/powerpc/registers.h: Add a few definitions for the PowerPC thermal assistance unit.
* 2003-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-112-1/+5
| | | | * configure.ac: Use rtems-bugs@rtems.com as bug report email address.
* 2003-07-18 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-07-182-2/+19
| | | | | | PR 288/rtems * rtems/new-exceptions/cpu.h: _ISR_Nest_level is now properly maintained and does not reside in SPRG0.
* Merger from rtems-4-6-branch.Ralf Corsepius2003-03-112-1/+4
* 2003-02-20 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-202-0/+7
| | | | | PR 349/bsps * rtems/powerpc/registers.h: Add definitions for HID1 and DABR SPRs.
* 2003-02-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2003-02-141-1/+1
| | | | | | PR 347/rtems * rtems/powerpc/registers.h (PPC_Set_decrementer): Correct inline assembly so it correctly generates on newer gcc's.
* 2002-12-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-12-113-7/+10
| | | | | * configure.ac: Require autoconf-2.57 + automake-1.7.2. * Makefile.am: Eliminate C_O_FILES, S_O_FILES, libscorecpu_a_OBJECTS.
* 2002-11-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-192-1/+5
| | | | * configure.ac: Fix package name.
* 2002-11-06 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-11-064-78/+55
| | | | | | | | | * rtems/new-exceptions/cpu.h: Remove sections on CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY. * rtems/old-exceptions/cpu.h: Remove sections on CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY. * rtems/score/cpu.h: Insert sections on CPU_INLINE_ENABLE_DISPATCH and CPU_UNROLL_ENQUEUE_PRIORITY.
* 2002-10-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-10-312-1/+9
| | | | * rtems/new-exceptions/cpu.h: Removed warnings.
* 2002-10-25 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-252-1/+5
| | | | * configure.ac: Add nostdinc to AM_INIT_AUTOMAKE.
* 2002-10-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-10-212-3/+9
| | | | | | * .cvsignore: Reformat. Add autom4te*cache. Remove autom4te.cache.
* 2002-07-26 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-262-7/+12
| | | | * Makefile.am: Build libscorecpu.a instead of rtems-cpu.rel.
* 2002-07-22 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-222-2/+6
| | | | * Makefile.am: Use .$(OBJEXT) instead of .o.
* 2002-07-05 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-052-1/+5
| | | | * configure.ac: RTEMS_TOP(../../../..).
* 2002-07-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-07-012-2/+4
| | | | * configure.ac: Remove RTEMS_PROJECT_ROOT.
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-0/+5
| | | | * configure.ac: Add RTEMS_PROG_CCAS
* 2002-06-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-272-1/+7
| | | | | * configure.ac: Use AC_CONFIG_AUX_DIR(../../../..). Add AC_PROG_RANLIB.
* 2002-06-17 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-06-172-5/+10
| | | | | * Makefile.am: Include $(top_srcdir)/../../../automake/*.am. Use ../../../aclocal.
* 2002-05-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-142-46/+4
| | | | * rtems/score/ppc.h: Remove PPC_DEBUG_MODEL.
* 2001-05-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2002-05-141-1/+8
| | | | | | | | | | | | | | | | | | | | | * rtems/new-exceptions/cpu.h: Per PR211 fix saving/restoring floating point context. The fpsave and fprestore routines are only used in a executing context which _is_ fp and hence has the FPU enabled. The current behavior required the FPU always to be on which is very dangerous if lazy context switching is used. [Joel Note: Some ports explicitly enabled the FPU in the FP save and restore routines to avoid this.] The patch also makes sure (on powerpc only) that the FPU is disabled for integer tasks. Note that this is crucial if deferred fp context switching is used. Otherwise, fp context corruption may go undetected! Also note that even tasks which merely push/pop FP registers to/from the stack without modifying them still MUST be FP tasks - otherwise (if lazy FP context switching is used), FP register corruption (of other, FP, tasks may occur)! Furthermore, (on PPC) by default, lazy FP context save/restore is _disabled_.
* 2001-05-14 Till Straumann <strauman@slac.stanford.edu>Joel Sherrill2002-05-143-0/+14
| | | | | | * rtems/powerpc/registers.h, rtems/score/ppc.h: Per PR213, add support for the MPC74000 (AKA G4); there is no AltiVec support yet, however.
* 2002-04-30 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-05-013-42/+19
| | | | | | | * rtems/score/ppc.h: Remove rtems_multilib. Add mpc555 (Based on comments from Sergei Organov <osv@javad.ru>). * rtems/old-exceptions/cpu.h: Remove _CPU_Data_Cache_Block_Flush. Remove _CPU_Data_Cache_Block_Invalidate.
* 2002-04-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-04-188-18/+383
| | | | | | | | | | | | * asm.h: Include cpuopts.h instead of targopts.h. * rtems/new-exceptions/cpu.h: Relocated from libbsp/powerpc/support/new_exception_processing/rtems/score/cpu.h * rtems/old-exceptions/cpu.h: Relocated from c/src/lib/libbsp/powerpc/support/old_exception_processing/rtems/score/cpu.h * rtems/powerpc/registers.h: Relocated and renamed from libcpu/powerpc/shared/include/cpu.h. * rtems/score/cpu.h: New. * Makefile.am: Reflect changes above.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-032-2/+2
| | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/cpu.h: Account for name change.
* 2001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-04-034-3/+10
| | | | | | | * Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/ppctypes.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
* 2002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-03-283-3/+9
* 2002-01-28 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-302-8/+21
| | | | * Makefile.am: Reflect changes from 2002-01-23.
* 2002-01-23 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-242-4/+9
| | | | | | | * rtems/Makefile.am: Removed. * rtems/score/Makefile.am: Removed. * configure.ac: Reflect changes above. AC_CONFIG_SRCDIR(asm.h).
* 2002-01-21 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2002-01-225-3/+50
| | | | | | | | | | | | | | | | | * rtems/Makefile.am: New. * rtems/.cvsignore: New. * rtems/score/Makefile.am: New. * rtems/score/.cvsignore: New. * rtems/score/ppc.h: Relocated from shared/. * rtems/score/ppctypes.h: Relocated from shared/. * asm.h: Relocated from shared/. * shared/Makefile.am: Removed. * shared/asm.h: Removed. * shared/ppc.h: Removed. * shared/ppctypes.h: Removed. * shared/.cvsignore: Removed. * Makefile.am: Reflect changes above. * configure.ac: Reflect changes above.
* 2001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill2001-11-281-0/+7
| | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
