Maximum number of processors of all systems supported by this CPU port.
Add CPU_CACHE_LINE_BYTES for the maximum cache line size in bytes. The
actual processor may use no cache or a smaller cache line size.
Update #2271.
This reduces the code size.
The e500v1 has no support for the ATB.
Update #2369.
The mftb is not available on Book E processors. Use SPR 268 instead.
Close #2369.
Update #2268.
Add AltiVec and FPU support to the Context_Control in case we use the
e6500 multilib.
Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add
non-volatile AltiVec and FPU context to Context_Control. Add save/restore of
non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore
of volatile AltiVec and FPU context to the exception code. Adjust data
cache optimizations for the new context and cache line size.
Provide floating point context support only if PPC_HAS_FPU == 1.
Simplify PPC_STACK_ALIGNMENT definition.
Use it for the default PPC_CACHE_ALIGNMENT. Use it for
PPC_STRUCTURE_ALIGNMENT.
Converting 64-bit nanoseconds values into the common struct timeval or
struct timespec formats requires a 64-bit division to get the seconds
value. Performance analysis of high network loads revealed that this is
too costly on PowerPC.
Rename _BSP_Exception_frame_print() to _CPU_Exception_frame_print() to
be in line with other CPU port functions.
Without the source the error code does not say that much.
Let it be up to the CPU/BSP to determine the error code
reported on fatal shutdown.
This patch does not change the current behaviour, just
adds the option to handle the source of the fatal halt.
not updated.
Fix context switch on SMP for ARM, PowerPC and SPARC.
Atomically test and set the is executing indicator of the heir context
to ensure that at most one processor uses the heir context. Break the
busy wait loop also due to heir updates.
We must not alter the is executing indicator in
_CPU_Context_Initialize() since this would cause an invalid state during
a self restart.
The is executing indicator must be valid at creation time since
otherwise _Thread_Kill_zombies() uses an undefined value for not started
threads. This could result in a system life lock.
The current implementation of task migration in RTEMS has some
implications with respect to the interrupt latency. It is crucial to
preserve the system invariant that a task can execute on at most one
processor in the system at a time. This is accomplished with a boolean
indicator in the task context. The processor architecture specific
low-level task context switch code will mark that a task context is no
longer executing and waits that the heir context stopped execution
before it restores the heir context and resumes execution of the heir
task. So there is one point in time in which a processor is without a
task. This is essential to avoid cyclic dependencies in case multiple
tasks migrate at once. Otherwise some supervising entity is necessary to
prevent life-locks. Such a global supervisor would lead to scalability
problems so this approach is not used. Currently the thread dispatch is
performed with interrupts disabled. So in case the heir task is
currently executing on another processor then this prolongs the time of
disabled interrupts since one processor has to wait for another
processor to make progress.
It is difficult to avoid this issue with the interrupt latency since
interrupts normally store the context of the interrupted task on its
stack. In case a task is marked as not executing we must not use its
task stack to store such an interrupt context. We cannot use the heir
stack before it stopped execution on another processor. So if we enable
interrupts during this transition we have to provide an alternative task
independent stack for this time frame. This issue needs further
investigation.
Add and use _CPU_SMP_Start_processor(). Add and use
_CPU_SMP_Finalize_initialization(). This makes most
_CPU_SMP_Initialize() functions a bit simpler since we can calculate the
minimum value of the count of processors requested by the application
configuration and the count of physically or virtually available
processors in the high-level code.
The CPU port has now the ability to signal a processor start failure.
With the support for clustered/partitioned scheduling the presence of
particular processors can be configured to be optional or mandatory.
There will be a fatal error only in case mandatory processors are not
present.
The CPU port may use a timeout to monitor the start of a processor.
Rename Priority_bit_map_Control in Priority_bit_map_Word.
Remove RTEMS_COMPILER_PURE_ATTRIBUTE from _SMP_Get_current_processor()
and all _CPU_SMP_Get_current_processor(). Make inline ASM statements
volatile again. Test smptests/smpmigration01 showed that GCC optimizes
too much otherwise.
Rename _Internal_error_Occurred() into _Terminate().
Rename bsp_smp_initialize() into _CPU_SMP_Initialize() since every CPU
port must supply this function.
Instead of SPRG0 (= special purpose register 272) use the new global
symbol _PPC_INTERRUPT_DISABLE_MASK to store the interrupt disable mask.
The benefit is that it is now possible to disable interrupts without
further run-time initialization in boot_card().
At least on Freescale e500 cores this leads also to a faster execution
since the mfmsr and mfspr instruction require four cycles to complete.
The instructions to load the mask value can execute while the mfmsr is
in progress.
Use a ticket lock implementation based on atomic operations. Delete CPU
port specific SMP lock implementations.
The instructions to get the processor current index have no
side-effects.
Delete _CPU_Context_switch_to_first_task_smp() and use
_CPU_Context_restore() instead.
Tested and implemented on ARM, m68k, PowerPC and SPARC. Other
architectures need more work.
The r2 may be used for thread-local storage.
Add proper license and copyright.
