* | powerpc: Add 64-bit context/interrupt support | Sebastian Huber | 2017-08-22 | 1 | -74/+91 |
| | | | | Update #3082. | ||||
* | powerpc: Fix AltiVec VSCR save/restore | Sebastian Huber | 2015-01-20 | 1 | -5/+5 |
* | powerpc: AltiVec and FPU context support | Sebastian Huber | 2015-01-13 | 1 | -2/+384 |
| | | | | | | | | | | | Add AltiVec and FPU support to the Context_Control in case we use the e6500 multilib. Add PPC_MULTILIB_ALTIVEC and PPC_MULTILIB_FPU multilib defines. Add non-volatile AltiVec and FPU context to Context_Control. Add save/restore of non-volatile AltiVec and FPU to _CPU_Context_switch(). Add save/restore of volatile AltiVec and FPU context to the exception code. Adjust data cache optimizations for the new context and cache line size. | ||||
* | powerpc: Add r2 to CPU context | Sebastian Huber | 2013-11-18 | 1 | -9/+4 |
| | | | | The r2 may be used for thread-local storage. | ||||
* | powerpc: Do not validate reserved XER bits | Sebastian Huber | 2013-11-18 | 1 | -2/+2 |
* | powerpc: Fix _CPU_Context_validate() | Sebastian Huber | 2013-08-13 | 1 | -1/+1 |
* | score: Add CPU context validation | Sebastian Huber | 2013-05-10 | 1 | -0/+263 |
