* asm.h: Add doxygen preamble.
* rtems/score/cpu.h: Add doxygen preamble.
* rtems/score/cpu_asm.h: Add doxygen preamble.
* rtems/score/or32.h: Add doxygen preamble.
* rtems/score/types.h: Add doxygen preamble.
* rtems/score/cpu.h: i960 obsoleted and all references removed.
* cpu.c, cpu_asm.c, rtems/score/cpu.h: Convert to using c99 fixed
size types.
* rtems/score/cpu.h: Obsoleting HP PA-RISC port and removing all
references.
* cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/cpu_asm.h,
rtems/score/or32.h, rtems/score/types.h: URL for license changed.
* rtems/score/cpu.h (_CPU_Initialize_vectors) Define to NULL
since it is not used.
* asm.h, rtems/score/cpu.h: Correct items that have changed since
RTEMS version or32 port was based upon.
* asm.h, cpu.c, cpu_asm.c, rtems/score/cpu.h, rtems/score/or32.h,
rtems/score/types.h: Merged from OpenCores CVS repository.
* rtems/score/or32types.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/cpu.h: Fix conditional to match current GCC.
This was tracked as PR91.
* Shell added for or32 port based on no_cpu port with names replaced.
