* | 2001-02-27 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-02-27 | 1 | -1/+1 |
| | | | | * rtems/score/cpu.h: Fix conditional to match current GCC. | ||||
* | 2001-11-28 Joel Sherrill <joel@OARcorp.com>, | Joel Sherrill | 2001-11-28 | 1 | -0/+7 |
| | | | | | | | This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation. | ||||
* | 2001-01-03 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-01-03 | 1 | -1/+13 |
| | | | | * rtems/score/cpu.h: Added _CPU_Initialize_vectors(). | ||||
* | 2000-08-11 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2000-08-11 | 7 | -0/+1419 |
* Shell added for or32 port based on no_cpu port with names replaced. |
