* rtems/score/or32types.h: Removed.
* rtems/score/types.h: New file via CVS magic.
* Makefile.am, rtems/score/cpu.h: Account for name change.
* rtems/score/cpu.h: Fix conditional to match current GCC.
This was tracked as PR91.
* Shell added for or32 port based on no_cpu port with names replaced.
