path: root/cpukit/score/cpu/or16/rtems (unfollow)
2002-07-312002-07-31 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-1337/+0
* .cvsignore, ChangeLog, asm.h, configure.ac, cpu.c, cpu_asm.c, rtems/score/.cvsignore, rtems/score/cpu.h, rtems/score/cpu_asm.h, rtems/score/or16.h, rtems/score/types.h: Removed as the or16 port was just a stub and only the OR32 port is getting worked on.
2002-04-032001-04-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* Per PR94, all rtems/score/CPUtypes.h are named rtems/score/types.h. * rtems/score/or16types.h: Removed. * rtems/score/types.h: New file via CVS magic. * Makefile.am, rtems/score/cpu.h: Account for name change.
2001-11-282001-11-28 Joel Sherrill <joel@OARcorp.com>,Joel Sherrill1-0/+7
This was tracked as PR91. * rtems/score/cpu.h: Added CPU_PROVIDES_ISR_IS_IN_PROGRESS macro which is used to specify if the port uses the standard macro for this (FALSE). A TRUE setting indicates the port provides its own implementation.
2001-01-032001-01-03 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+13
2000-08-112000-08-11 Joel Sherrill <joel@OARcorp.com>Joel Sherrill6-0/+1318
* Shell added for or16 port based on no_cpu port with names replaced.
